585,996 active members*
4,522 visitors online*
    Oct 2019
    9
    motor sizing?
    Hello all! I'm new to the cnc retro world. And wanted to purchase a CNC trainer lathe. However I decided that it would be more beneficial in the future to build a 4th axis . I am curious about motor sizing in regards to weight holding/stopping/starting. I purchased my mill already converted and need to install limits and homing switches. And for some reason my mach 2 doesn't show any activity in the encoder portion of the screen. ( but that's a different issue)
    Any insight to proper sizing to hold ( start / Stop precisely ) will be greatly appreciated. I'm guessing my maximum weight to be 10#.
    I would only like to build this unit once. No upgrades for heavier product or motor inefficiencies.
    Apr 2004
    5737
    Re: motor sizing?
    Are you providing a planetary gear for this rotary axis, or just sticking a chuck on the end of a motor? With the gearing, you can use a much smaller motor than with the direct-drive plan. The ratio would factor in the torque required. The weight of your workpiece isn't that significant; it's the force required to turn it while cutting that makes more difference.
    Andrew Werby
    Website
    24221
    Re: motor sizing?
    There is a sizing program on the Kollmorgen site that used to be very useful for sizing.
    Al.
    Albert E.
  1. Help Sizing a motor
    By cuetipper in forum Linear and Rotary Motion
    Last Post: 12-05-2012, 10:41 PM
  2. Motor sizing
    By cmengnr in forum Controller & Computer Solutions
    Last Post: 02-02-2011, 06:08 PM
  3. Stepper Motor Sizing???
    By w102acd in forum Hobbycnc (Products)
    Last Post: 04-15-2009, 04:18 AM
  4. Stepper Motor sizing
    By hanschristopher in forum Stepper Motors / Drives
    Last Post: 03-15-2009, 06:23 AM
  5. Help with motor sizing
    By flinty in forum Servo Motors / Drives
    Last Post: 02-08-2005, 10:44 AM
