585,663 active members*
2,963 visitors online*
Results 1 to 1 of 1
    Taig CNC Mill in NJ
    For sale is a Taig CNC mill. This model is the larger 12” table with leadscrews. Included with the mill is the stand, computer with Mach3 and Cut3D, monitor, stepper driver, Z-Bot jog dial, and 2” screwless vise and parallels.
    This mill has some upgrades from the previous owner which include:
    - 2 hp, 4700 RPM treadmill motor with Pentadrive KBMD DC speed controller
    -420oz-in NEMA 23 steppers on all axes
    Condition:
    This mill has been well used and has seen some rust from the previous owner using improper coolant. When I received it I tore it down, addressed most of the rust, updated the motor couplings to Ruland oldham couplings, replaced the spindle bearings, and got everything adjusted nicely. There is about 1 thousandths backlash in the X-axis and about 4 thousandths in the Y-axis. The table surface is in mostly good condition, with one major drill mark and some smaller marks in other places. The mill operates well and I have cut plenty of brass and aluminum (and a little bit of steel on a 1-2-3 block on accident). If you want to get rid of the backlash I recommend replacing the leadscrews/nuts/couplers which is about $160. The cost of this is reflected in the price. Otherwise, this mill is good to go and 100% functional.
    Please let me know if you would like more photographs, videos, or have any questions.
    No shipping. Located in central New Jersey area, pick up preferred but this can be discussed depending on distance. $1900
    Attached Thumbnails Attached Thumbnails DSC_5624r.jpg   DSC_5628r.jpg   DSC_5629r.jpg   DSC_5630r.jpg
  1. Taig 3 Jaw Chuck on Taig Mill?
    By jim_stoll in forum Taig Mills / Lathes
    Last Post: 09-19-2017, 04:38 PM
  2. TAIG CNC Mill -Micro Mill 2000 Cnc
    By naji in forum For Sale Only
    Last Post: 08-13-2015, 04:06 AM
  3. Feeds and speeds for ABS or PLA on a Taig mill w/miniature end mill
    By theclay in forum Material Machining Solutions
    Last Post: 08-12-2015, 09:04 PM
  4. Where to find Shell mill / Face mill arbor for taig
    By 725franky in forum Taig Mills / Lathes
    Last Post: 11-18-2009, 11:48 PM
  5. Coming Down to the Taig Micro Mill or Grizzly Mini Mill.
    By CROSSHATCH in forum Taig Mills / Lathes
    Last Post: 01-23-2009, 06:14 AM
