585,930 active members*
3,990 visitors online*
    Question Power Relay Location
    So I'm thinking about a 40A power relay to control my router for off/on/e-stop. The economical ones seem to all be open contact style.
    Doesn't the arcing contacts generate a lot of EMI, RFI? Shouldn't the power relay be located out side the main control enclosure to prevent interference with the Ethernet boards, digital step drivers etc? Or any contact rely for that matter?
    Dec 2013
    5717
    Re: Power Relay Location
    I've not had any trouble using those. Just make sure the system grounding is good. All the grounds should come back to a single point in the panel. Consider that the contacts close at the start of the job, before any other machine movement, and they open again after the job is complete when the machine is parked. No problem.
    Jim Dawson
    Sandy, Oregon, USA
    Apr 2016
    43
    There is also RC-supressors that can be connected in paralell with the relay coil if you experience any problems.
  1. Estop wiring with relay to cut power. Please help
    By LazyMan in forum CNC Machine Related Electronics
    Last Post: 05-15-2016, 04:06 AM
  2. Heat sensor relay location
    By rswdew in forum Okuma
    Last Post: 01-22-2014, 08:26 PM
  3. 200VDC Power Relay
    By Tig in forum CNC Machine Related Electronics
    Last Post: 06-06-2007, 09:09 PM
  4. Relay vs Router power ratings
    By sol in forum CNC Machine Related Electronics
    Last Post: 06-24-2004, 03:17 AM
