585,667 active members*
3,968 visitors online*
IndustryArena Forum > CAD Software > Uncategorised CAD Discussion > Helical twist of a 3D CAD file
    Jan 2015
    I would like to wrap a 3D design of a guitar neck in a helical pattern around a central axis.
    My intent is to create a 4th axis toolpath in Aspire and mill the guitar neck as an artwork project.
    Once I figure out the neck, I'll apply a similar process to the body of the guitar and mount the neck and body in a frame.
    Please advise of a program (freeware if possible) that can accomplish the helical twist.
    1213
    Re: Helical twist of a 3D CAD file
    If you plan on doing this as a full size project you may need access to a very large machine with a very high 4th axis centre.I expect Fusion could do it,but haven't ever used it myself. A good number of paid programs would do the job and the people with a large enough machine to produce a full size job would have them.I would think that if you model the components in a program of your choice and save them in Step or STL form,the sweep along a helical path wouldn't be too demanding,once you determine the helix characteristics.
    Jan 2015
    Quote Originally Posted by routalot View Post
    ... if you model the components in a program of your choice and save them in Step or STL form,the sweep along a helical path wouldn't be too demanding,once you determine the helix characteristics.
    The following Fusion 360 video provides the process to achieve the twist I am looking for in the guitar neck CAD file:
    https://knowledge.autodesk.com/support/fusion-360/getting-started/caas/screencast/Main/Details/f1e948ba-4fb7-49d2-8ca6-e1b51f794c71.html
    Regards,
    Wayne L.
  1. Y Gantry Twist
    By OneWound in forum DIY CNC Router Table Machines
    Last Post: 09-26-2017, 07:28 AM
  2. Sweep Twist
    By RAF. in forum BobCad-Cam
    Last Post: 09-12-2015, 03:09 AM
  3. Tag with a (Celtic) twist.
    By cncadmin in forum EnRoute
    Last Post: 09-28-2011, 08:00 AM
  4. Helical macro via library file
    By ungie in forum Okuma
    Last Post: 07-13-2011, 09:29 AM
  5. DIY with a twist or a turn
    By M08M09 in forum DIY CNC Router Table Machines
    Last Post: 02-14-2007, 02:18 AM
