585,760 active members*
3,844 visitors online*
Results 1 to 8 of 8
    Dec 2005
    4
    Stepper Motors not working on new Sainsmart MX3 3018
    I have a new Sainsmart CNC Router 3018-MX3 assembled and Mach3 installed. Control board has a red and green lights on. The spindle motor spins when running a supplied g-code file. The stepper motors do not move in x, y or z directions. Actually there is no sound from stepper motors. The Mach3 screen does shows X, Y, & Z movements when using the jog functions. Any tips/suggestions as to how I trouble shoot this problem.
    Apr 2004
    5735
    Re: Stepper Motors not working on new Sainsmart MX3 3018
    Are you running this machine off the parallel port or are you using a USB or ethernet adapter?
    Andrew Werby
    Website
    Dec 2005
    4
    Andrew,
    I am using a USB connection.
    Apr 2004
    5735
    There may be an issue with your USB adapter, then. Which one are you using?
    Andrew Werby
    Website
    Dec 2005
    4
    I am using a USB cable supplied with kit. Computer is a desktop running Windows 10.
    Jan 2007
    626
    Did you copy a 'plugin'for your Control Board into your C:\mach3/plugin folder?
    Dec 2005
    4
    Stepper motors are now working! Thanks everyone for your suggestions. I had copied and pasted the PlugIns and Mach3Mill.xml files. But I did it again and the motors worked. Thanks again.
    Jan 2020
    5
    I have the same CNC, the MX3.
    Same problem as you are having. The image inside the display on the Mach3 interface shows the milling running at normal speed. The spindle is turning at the correct RPM. But my stepper motors are clicking because they are running at micro stepping.
    When I setup the software, I copied the XML file to the Mach3 folder the the BL_USB.Dll file to the plugins folder.
    But I still have the same problem.
    Can you offer any suggestions?
  1. sainsmart 3018 MX3 laser does not immediately honour M3/M5
    By lawrencek in forum Mach Software (ArtSoft software)
    Last Post: 10-16-2019, 05:39 PM
  2. Sainsmart 3018 Pro using Grbl
    By portanav in forum CamSoft Products
    Last Post: 07-30-2019, 04:10 PM
  3. woodpecker 3018 problems with X and Y axis and stepper motors
    By javierfernandez in forum Chinese Machines
    Last Post: 07-16-2018, 10:39 PM
  4. Sainsmart 2M542 Drivers Not Working
    By minimill in forum Stepper Motors / Drives
    Last Post: 12-30-2016, 04:44 AM
  5. Stepper Motors not working Please help
    By emh114 in forum Stepper Motors / Drives
    Last Post: 01-14-2016, 02:50 AM
