586,000 active members*
4,922 visitors online*
Results 1 to 13 of 13
    Zero touch prob
    Hello. Does anyone have a photo of the wiring of a zero touch probe to a PRT-E1500 or a link to were i can find this info .Thank you for any support.
    Mar 2007
    2083
    Re: Zero touch prob
    PRT-E1500 with be the model number for the VFD drive for the spindle motor
    various Chinese CNC machine builders make control boxes that look identical on the outside but the electronics inside can be very different
    some use an all in one BOB & stepper drivers on a single board
    others a BOB & individual stepper drivers
    Photos of the inside showing the printed circuit boards will help identify what you have
    some times they don't always install all the components to the BOB's PCB used in machines without a connector to plug in a touch probe
    example of a BOB with some parts not installed
    Attachment 430218
    photo taken of the net showing the inside of a CNC machines control box
    the PRT-E1500 VFD board is in the foreground
    Attachment 430220
    John
    Re: Zero touch prob
    Thank you John for your reply. I will Take some photos. and return back.
    Re: Zero touch prob
    Hi John. Here are the photos. the 2 holes are where i was going to put a connection for the touch probe so the wires don't go straight through.
    James
    Mar 2007
    2083
    Re: Zero touch prob
    Hi James
    you need to connect the probe to the red board in your first photo
    this is the USb motion controller you have
    Attachment 430264
    looking closer the board has 4 inputs
    Attachment 430266
    assuming the board replicates a PC parallel printer port
    I guess IN1 to IN4 on the board will be pins 10 to 14 in mach 3 /4s pins and ports set up
    I expect the terminal DCM is going to be the common terminal for the 4 inputs
    it looks like the 4 opto-isolators LEDs are connected to +24V via 4 resistors to limit the LED current
    when an input terminal ( IN1 to IN4 ) is grounded to the terminal DCM
    John
    PS
    possible input wiring
    Attachment 430268
    Re: Zero touch prob
    Thank you John for taking the time out of your life to help me it is much appreciated and honorable. Just a recap if i put the probe wire into IN2 and the ground into DCM then im good to go. In the first photo if you look at the top on 5v you can see 4 wires that are twisted together,one of them was just barly holding so in the next photo all fixed gloud i found that.
    Re: Zero touch prob
    Hi John. Photo of installed wires hope its all the right way. haven't turn the power on as yet waiting for your reply. the red colour is probe and the the green is ground. James
    Mar 2007
    2083
    Re: Zero touch prob
    Hi James
    that looks correct
    do you have a multimeter ?
    can you confirm one of the black wires connected to terminal DCM goes to the 24V power supplies negative output terminal
    and a red wire connected to the 24V terminal goes to the 24V power supplies positive output
    which touch probe do you have ?
    is the probe isolated from the machine
    or does it connect the machines body / spindle to the motion controller connection DCM terminal (the green wire ) ?
    John
    Re: Zero touch prob
    Hi John. Here is the photo of the prob. I have a friend who is a tv repair man, he has no knowledge of cnc probes but he check it for me and it was showing 22.8 v. This is not my area of knowledge and have never used a multimeter but this looks like its going to work I will now set it up in mach3. I will give you feed back and hopfuly a vidio as well. Thank you very much John will return tommrow. James.
    Re: Zero touch prob
    Hi John. I open up mach3 and tested the prob this is whats happening. In photo 1 shows when the tool touches probe. The second pic is settings. 3rd pic needs a script g-code, can you recomend any that is in metric. Thank you.... James
    Mar 2007
    2083
    Re: Zero touch prob
    Hi James
    The probe wiring in post 9 looks correct with the isolated touch plate connected to the boards input
    Looking at the second photo in post 10 the probe is assigned to pin 15
    As the board only has 4 inputs I expect you need to assign the probe to one of the other 4 possible input pins - pins 10 to 13
    I have not used scripts with mach 3 so I can't answer your last question
    John
    Re: Zero touch prob
    Hi John. Can't seem to stop it activating the e-stop. when i touch the two togeather it should light up the digitize as in the photo and not the others. I played around with ports and pin settings with no success. Not sure what to do now. Ill have to do more reserch and hopfuly find a answer to this. I would like to thank you for your time and help John. Im a little bit further today then i was a few days ago and for that i thank. James
    Re: Zero touch prob
    Hi John. I found a photo online showing the probe wiring. Hope it can help others. James
  1. Renshaw prob?
    By Redzilla in forum Tree
    Last Post: 03-11-2016, 06:17 AM
  2. Replies: 12
    Last Post: 06-05-2013, 06:05 PM
  3. renishawe prob
    By dek in forum Bridgeport / Hardinge Mills
    Last Post: 06-20-2011, 05:21 PM
  4. VFD METER PROB
    By SIGNMAD in forum Excitech routers
    Last Post: 11-13-2008, 06:39 AM
  5. sheet cam prob
    By fastimes in forum SheetCam
    Last Post: 07-29-2006, 03:11 AM
