585,991 active members*
4,725 visitors online*
Results 1 to 17 of 17
    Sep 2019
    197
    Huanyang Inverter
    Hi, i am looking for the dimensions of the above for a 2.2KW. Can anyone please assist, tried but not ale to find this in any manuals i looked at?
    Erick
    Re: Huanyang Inverter
    If nobody replies, remind me in about 12 hours and I'll measure mine tonight.
    Sep 2019
    197
    Thanks Gerry
    Sep 2019
    197
    Hi Gerry....can you please get me those sizes when you get a chance?
    Erick
    Unfortunately, when I went to leave work yesterday, the battery in my truck was dead, which led to a two hour ordeal to get home, followed by an hour to change the battery, make dinner, and go to sleep.
    I'll get the info tonight.
    Sep 2019
    197
    No problem, whenever you get a chance
    Feb 2005
    750
    My HY 3KW VFD is 5"wide, 7 inches tall and 6 inches deep. Pretty sure the 2.2 and the 3K are the same size.
    Halfnutz
    Sep 2019
    197
    Quote Originally Posted by Halfnutz View Post
    Great, thanks
    15362
    Quote Originally Posted by ericks View Post
    Great, thanks
    I'm sure you are aware,but make sure you have enough room around the drive, this is just a manufacturer's guide they can have less room than this though, plus room for the EMI power filter I like this TDK EMI filter as it performs better than most others
    Mactec54
    Sep 2019
    197
    Thanks, as usual i don't have the luxury to have the space i'd like. It's going to be a tight squeeze. Reason i asked for the hy is not because i plan to use one, just in case a customer insists i use/install one
    OK, It's about 130mm wide, 170mm tall, and is about 160mm deep from the back plate.
    Sep 2019
    197
    Thank you
    Which is basically the same size as Halfnutz. In inches, I had 5" x 6-3/4" x 6". But I figured that you'd prefer mm's.
    Sep 2019
    197
    I do honestly i am no good at working in inches!!
    The chinese drive i bought today almost matches that size. That leaves the option to fit a hy if required. I recently had a 2.2Kw hy in my workshop, was going to take sizes but completely forgot
    Thanks for the info
    15362
    Hitachi is another one that is used quite a lot, so if you can fit these, then you should be able to fit anything else that is out there in that power rating of your cabinet
    Inches to millimeters is very easy 5" x 25.4=127mm or if you want inches ( not likely ) 127mm / 25.4=5"
    Mactec54
    Sep 2019
    197
    Yep...i use a converter on google
    Sep 2019
    197
    Hitachi is okay but i expect it to be above my budget. I found a 2.2KW for $200 AU
  1. HUANYANG INVERTER AND SPINDLE SET UP
    By MTMOOSE797 in forum Phase Converters
    Last Post: 04-22-2017, 03:39 PM
  2. huanyang inverter HY020223B 3hp 2.2kw
    By holder1944 in forum Phase Converters
    Last Post: 07-17-2013, 03:14 PM
  3. 220V in to Huanyang Inverter
    By Jerry In Maine in forum DIY CNC Router Table Machines
    Last Post: 04-13-2013, 01:43 AM
  4. huanyang inverter burn
    By edgas10 in forum CNC Machine Related Electronics
    Last Post: 07-02-2012, 06:42 PM
  5. Huanyang inverter
    By mdileva in forum Phase Converters
    Last Post: 06-18-2012, 03:24 PM
