Originally Posted by
pwccycles
Greetings,
I am having a problem with a shifting x,y,z origin on my Nema 23 4x4 pro table. I turn everything on, initialize the table zeros in Mach4 and set my work origin. I will then do a cut, occasionally stopping it in the middle if I don't like what is happening which may or may not be the cause if the issue. What's happening is the x,y,z zero moves slightly. I'm not sure if it's the stepper motors getting out of sync or mach4 losing track of where the "zero" is. I noted this by moving the bit to the zero position and checking.
Has anyone else noticed this behavior? Ideas or suggestions to troubleshoot would be appreciated as I'm still learning!
Thanks!
Perry
