The blade could rotate +/-360 for foam cutting usually, then it is necessary to reset the blade position during cutting when there are one more parts cutting continuously.
CutLeader provided the feature of chain cutting for all parts automatically, but also the feature to set the reset blade positin.
Because a small node would be generated when the blade return to 0 deg, the position is put on the path outside of the part usually. User could set the reset position at any where they want , and a specific reset command would be genereted for the foam cutting machine.
Attachment 430254
