508,649 active members
4,213 visitors online
Results 1 to 8 of 8
    Oct 2019
    5
    THC under Linux
    I have a CNC router running step and direction geckos 320s . Can I use Mesa and THC10 to convert to plasma cutting ? Is Linux cnc plasma directly controlling THC? I see all this reference to encoders.That why I ask.
    Registered
    Feb 2008
    591
    Re: THC under Linux
    Quote Originally Posted by saily View Post
    Yes, all the brains of the THC are done in LinuxCNC in real time.
    The THCAD is just a high isolation V-F card to capture the plasma voltage
    Encoders inputs are generally used to read the THCAD since they can
    read frequency (and the THCAD outputs a frequency proportional to plasma voltage)
    Oct 2019
    5
    Re: THC under Linux
    Oct 2019
    5
    Re: THC under Linux
    Do I need any other boards to interface the messa THC10 to the computer. Can you point me in the right direction?
    Registered
    Feb 2008
    591
    Re: THC under Linux
    You can use the THCAD-10 with a Parallel port LinuxCNC system but you will be somewhat limited in resolution/bandwidth
    Normally the THCAD would be used with a LinuxCNC compatible step/dir/IO controller like a Mesa 7I96 that has a built in
    encoder/frequency counter input.
    Oct 2019
    5
    Re: THC under Linux
    One last question ,... The Mesa 7I96 is Ethernet connected ? Can I use the Mesa 7i78 instead as I'm already set up using the printer port. Without the need for a 5i25 ? Just looking for a low cost combo. Don't want to order without understanding what works together. Thank You for your help.
    Registered
    Feb 2008
    591
    Re: THC under Linux
    The 7I96 is Ethernet connected. This is an advantage in Plasma systems as it provides an additional level of noise isolation.
    I don't think you can use a 7I78 with a parallel port, most Mesa daughtercards depend on the ability of the controller being able
    to set the direction of all I/O pins on a pin-by-pin basis (something that parallel ports cannot do). Mesa FPGA cards can work
    with standard parallel port breakouts, but in general Mesa daughtercards will not work with parallel ports.
    Using a THCAD with common breakouts might be an issue also depending on how fast the inputs can be read.
    Many cheap breakouts are limited to a few KHz on inputs due the Opto-coupler / associated
    circuitry used. The THCAD has a nominal 1 MHz full scale output but this can be lowered to about 8 KHz full
    scale by selecting the 1/128 mode, if the parallel port BOB can pass this signal to LinuxCNC, it should work
    Oct 2019
    5
    Re: THC under Linux
  1. new to linux- where exactly is LINUX CNC located in the computer?
    By js412000 in forum LinuxCNC (formerly EMC2)
    Last Post: 03-03-2014, 11:00 PM
  2. Linux(P?)CNC
    By SomeWhatLost in forum Tormach Personal CNC Mill
    Last Post: 07-23-2013, 11:15 PM
  3. CAD and CAM for linux ?
    By bianchi in forum LinuxCNC (formerly EMC2)
    Last Post: 07-16-2012, 10:40 PM
  4. 40W under linux
    By atarkri in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 04-22-2011, 06:21 PM
  5. BDI Linux
    By ynneb in forum LinuxCNC (formerly EMC2)
    Last Post: 08-03-2004, 10:38 PM
