586,005 active members*
5,077 visitors online*
IndustryArena Forum > CAD Software > Autodesk > I cannot generate a 2D contour tool path for the word CHRISTMAS
    Mar 2011
    357
    Question I cannot generate a 2D contour tool path for the word CHRISTMAS
    I have created a sketch with the word Christmas. All I am trying to do is cut this word out using a 2D contour tool path but I CANNOT select the geometry. I can select the leading C but the rest of the text, which was all created at the same time, I cannot select. If I create Merry Christmas I can select the M and the erry and the C but not the hristmas.
    See attached Paint (.png) file.
    I don't get it.
    The text is create as follows.
    I create a new sketch.
    I do a create text and set up the text.
    I accept the text.
    I do an explode text.
    I trim out the extraneous lines.
    I finish the sketch.
    I select all the letters.
    I do a press pull for .121 inches.
    I go to manufacture and create a new setup.
    I select the 2D contour and TRY to select all the contours but I can only select the C.
    Attachment 430422
    This has worked perfectly in the past and works now with the word Merry but not with Christmas.
    Even if I leave off the C the rest of the word will not allow me to select it. All I get are a bunch of little segments instead of the entire outline.
    I don't get it.
    I attached the fusion file.
    If anybody has a clue about this please help.
    Jun 2012
    182
    Re: I cannot generate a 2D contour tool path for the word CHRISTMAS
    I'm sure you've figured this out by now. For others, 2D toolpaths can be created directly from sketches. You don't need to extrude a 3d model.
    Mar 2011
    357
    Quote Originally Posted by elfrench View Post
    how do you tell the tool path how deep to go without a 3D model?
    In the toolpath settings, under "Heights", depth of cut is "Bottom Height"
    Jun 2012
    182
    You can also use a negative number in Stock to Leave, Ger21's suggestion is preferred.
  1. MACH3 wont generate tool path
    By ProtoXNH in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 07-24-2017, 10:34 PM
  2. Replies: 7
    Last Post: 04-08-2015, 03:13 PM
  3. Generate tool path for woodruff keyseat cutter to do undercuts
    By dalianharley in forum Tormach Personal CNC Mill
    Last Post: 06-09-2014, 01:08 PM
  4. How to Generate a CNC code from measured 3D tool path
    By smar in forum OpenSource Software
    Last Post: 04-02-2009, 06:51 PM
