585,763 active members*
4,408 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Vise attached to aluminum extrusion directly.
Results 1 to 10 of 10
    Feb 2005
    829
    Somewhere on CNCZone someone posted a picture of a AVIDCNC type machine with a removable spoilboard in order to bolt a machine vise directly to the aluminum extrusions of the machine.
    Anyone know who that was or have the link to that machine? Asking for another CNCZONE member, and me!
    May 2005
    3920
    Re: Vise attached to aluminum extrusion directly.
    No memory on that one!
    I suspect though that you will need a precise frame to take advantage of a machine too vise. The problem is that yo have nothing to machine flat and in parallel to the X axis plane.
    Feb 2005
    829
    You can certainly machine the surface of the 80/20 extrusions that you are bolting the vise too. Or add a piece of aluminum to bolt the vise too, and machine that.
    Jun 2018
    362
    Quote Originally Posted by nlancaster View Post
    IIRC, this is buried somewhere in a thread about the Saturn 3 machine and was about some 6 months ago.
    Jan 2007
    626
    Is this it?
Name:	Vice on Router.jpg
    I saved the pic when I saw it, but don't know where it came from.
    May 2005
    3920
    I’m not sure I like the idea of machining any T-slotted aluminum. The stuff can be pretty thin to begin with. If the machine is close to square and parallel you might get away with it. In general though I can’t suggest this approach.
    On the other hand adding an aluminum plate is almost ideal. Actually this could be a steel plate too, as long as it can be machined. Done right this should give a solid mounting point for the vise.
    Feb 2005
    829
    Sterob, YES THAT IS THE ONE!!
    Now if I could just find the thread!
    Thanks.|
    So if anyone recognizes that machine and which thread it was, a link would be great. I still can't find it even though I know that is a pre january 2016 cncrouterparts machine.
    Jan 2007
    626
    Thanks.|
    Your welcome.lol
    Aug 2005
    58
    Hi, This is my machine. I have an two different pics of it in two separate threads.
    https://www.cnczone.com/forums/cnc-r...rmach-cam.html
    https://www.cnczone.com/forums/cnc-r...ml#post2282248
    The extrusion is machined flat as you would a spoil board. I used to have it mounted low enough that I could place the spoil board back and cover the entire setup without taking off the vice, but I found that I was sacrificing too much rigidity when the Z is that low. You might do better with the newer linear rail machine but the V-con chatters loudly at the speeds I tried to hit. So basically the setup is now fixed and I have 1/4 area reserved for aluminum or really tall pieces. The extrusion surface is machined flat as you would a spoil-board maybe taking off 0.03". I have a couple vises mounted now and a removable plastic tray underneath to catch chips and coolant
    Hope this helps.
    I scored a linear rail Servo based machine sometime ago which I intend to setup for all metal cutting. Not sure when I'll get to that.
    https://www.cnczone.com/forums/cnc-r...ml#post2316832
    Feb 2005
    829
    Thanks for the input panda!!
    Yeah saw your thread on the pro machine with servos. can't wait to see what you do with that!
  1. aluminum extrusion
    By Gary N. in forum Want To Buy...Need help!
    Last Post: 04-07-2018, 04:39 PM
  2. Aluminum Extrusion
    By MICHEL15 in forum Other Manufacturing Processes
    Last Post: 10-13-2015, 11:53 AM
  3. aluminum extrusion
    By georgebarr in forum DIY CNC Router Table Machines
    Last Post: 05-14-2013, 09:03 AM
  4. Aluminum extrusion
    By ssgtbair in forum DIY CNC Router Table Machines
    Last Post: 12-05-2012, 07:22 AM
  5. Aluminum extrusion
    By Pysiek in forum RFQ (Request for Quote)
    Last Post: 07-21-2012, 05:20 PM
