585,987 active members*
4,559 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Tormach PathPilot™ > PathPilot Manual not in Dual Column mode ??
Results 1 to 8 of 8
    Oct 2005
    1145
    Does anyone know of a copy of the PathPilot manual that is NOT in 2 column mode ??
    (;-) TP
    Nov 2007
    2151
    Re: PathPilot Manual not in Dual Column mode ??
    Quote Originally Posted by vmax549 View Post
    (;-) TP
    All my PDF Files load and display per the current settings. Easy to change as desired.
    Oct 2005
    1145
    Sorry but I don't follow you. I have adobe reader and do not see any options for changing how it is displayed.
    (;-) TP
    Aug 2014
    257
    Hmm, when displaying PDF documents with a reader the format is fixed by the author. You cannot change this within a reader program.
    All the Tormach manuals I've ever seen are single column. I'm thinking you are seeing the pages displayed side by side such as this:
    And what you're looking for is something like this:
    Or this:
    This is called simply setting the page mode, side-by-side, single fit page, single fit width & etc. These settings are accessed using various menus in your reader. I use Foxit Reader so how this is accomplished is different than Adobe reader.
    Anyway, if this is not what you're talking about I have no idea what you mean???
    P.S. I find Foxit Reader to be a better reader than Adobe and it's free. You can also install it on your controller since there is a linux version too. Nothing like having the manual right on your machine.
    Oct 2005
    1145
    Here is a simple example of single column and dual column. The manual is a mix of both and makes it harder to read. Multi column mode is normal used in newspaper printing. But it make a poor book format.
    (;-) TP
    Aug 2014
    257
    OK, you cannot do anything about that because the author (Tormach) decided to lay it out like that. Using a reader you can only view the document as is.
    If you have a PDF editor then you could re-edit the document to your liking assuming the security setting allows it.
    Looking at my PCNC 1100 S3 manual (PDF) I see that Tormach does allow anyone to change the document. So if you have a PDF editor & some TIME you could make it anyway you like!
    Nov 2007
    2151
    I see, forgot this all changed a while back for me.
    I view pdf with windows 10 web browser / pdf reader, yet a different method from shown above. I get options for 1 or 2 pages, text size, format, table of context even have it read out loud.
    Microsoft constantly changes how this stuff works when you use their basic products. I tend to change / adapt pretty fast and forget what I used before.
    I see manual for MX shown above. Did you pick one up?
    Oct 2005
    1145
    No But I am converting a Bridgeport VMC with ATC over to their software using teh MX profile.
    (;-) TP
  1. Dual monitors while in pathpilot
    By ally-g in forum Tormach PathPilot™
    Last Post: 08-16-2018, 11:07 AM
  2. PathPilot Manual NC message
    By jmosley in forum Tormach Personal CNC Mill
    Last Post: 08-01-2016, 05:37 PM
  3. PathPilot manual
    By ErnieD in forum Tormach PathPilot™
    Last Post: 04-12-2015, 12:20 AM
  4. Manual Tool Changes - PathPilot / Fusion 360
    By nickfabb in forum Tormach PathPilot™
    Last Post: 03-17-2015, 01:22 AM
  5. Taig Z Axis Column Torque? Manual?
    By cwm9 in forum Taig Mills / Lathes
    Last Post: 11-18-2008, 05:00 AM
