585,753 active members*
3,807 visitors online*
Thread: Wifi adapter
Results 1 to 9 of 9
    Jun 2014
    1780
    Wifi adapter
    I have a question for computer savvy guys, I need a usb type wi fi adapter for my PP 1100 computer that will connect to my wifi home system, I had one and broke it, and I cant find where I bought that one. I have no idea which one to buy?
    Its not a real big deal but I would like to get PP updates over the net etc.
    Any help appreciated!!
    mike sr
    Nov 2007
    2151
    Re: Wifi adapter
    Quote Originally Posted by popspipes View Post
    I didn't think there was much difference in usb or most computer devices, Plug and pray is normal.
    I have to use a hardwire network, my home is like a faraday cage and wifi only goes out the windows. Still took Tormachs help to set the controller up correctly to network . Some un published settings in files that had to be edited. Now after only a week of using it I wonder why I waited 2 years to put a switch in shop and patch in
    Jun 2014
    1780
    Re: Wifi adapter
    I had a little usb adapter plugged into the outside usb port, moved the 20 gallon chip can under the machine and snapped it off, dumb mistake on my part!!
    I bought one from Tormach originally and had heard that there are some available on ebay that work as well, just wondering if some one had the info etc.
    Like my Dad used to say, If I wasnt so dang dumb I would be pretty smart!!!!
    mike sr
    Aug 2014
    257
    Re: Wifi adapter
    The one I like is EDIMAX and is known to work well with Linux.
    You can pick one up at Amazon for $14 with free shipping.
    If you look around you might find it somewhere else cheaper, free shipping, no tax and/or used ...
    If at all possible it's much better to run some Cat 5e cable from you controller to your switch.
    Jun 2014
    1780
    Re: Wifi adapter
    Thank you sir!
    Cat 5 Im sure is much better, the problem is running the cable, Im well past the age of getting in the atitic and running cable........
    thanks again!
    mike sr
    Mar 2019
    34
    Re: Wifi adapter
    This one works perfect for us. Under 3 bucks with free shipping.
    https://rover.ebay.com/rover/0/0/0?m...2F192872501044
    Sent from my iPad using Tapatalk Pro
    Jun 2014
    1780
    Re: Wifi adapter
    I bought one earlier today, Edimax as suggested earlier.
    I bought one of those 802.11n, I couldnt get it to work??
    Quote Originally Posted by sd624 View Post
    mike sr
    Nov 2007
    2151
    Re: Wifi adapter
    I didn't even think of that! Forgot about old 802.11 routers and hardware still being around.
    Figured rdsi had some quick correct info on the subject.
    Jun 2014
    1780
    Re: Wifi adapter
    Thanks for your help guys!
    I know enough about computers and programming and hardware to be dangerous!
    mike sr
  1. Help US converters WiFi Adapter WF5000B DNC
    By mattmont3 in forum Fanuc
    Last Post: 11-20-2019, 06:11 PM
  2. MACH3 WIFI JOG out of a mini wifi Keypad
    By QUOY in forum Mach Software (ArtSoft software)
    Last Post: 10-31-2019, 08:44 AM
  3. Connecting arduino to WiFi
    By hfjbuis in forum Arduino
    Last Post: 06-15-2018, 11:29 AM
  4. wifi
    By steve brest in forum Fanuc
    Last Post: 01-11-2014, 01:53 AM
