First of all, I am completely novice and would be happy to help.
A few words about planning, if there is anything I did not write please ask.
The X-axis sits on a steel frame Length 145 cm on Width of CM 130.
Linear rails on both sides and screw in the middle
2pc HB30-1450 rails with 2 HBH30CA
ballscrew SFU2510-1450mm
Nema 42 stepper motors 110BYGH201-001 8A 30N-m (4200oz-in)
Driver Stepper MOTOR DQ2722M 220V AC is powered
The Y axis sits on aluminum supports, and the axis itself sits on a ready-made aluminum plate
Something like that
2pc HB20-1000 rails with 2 HBH20CA
ballscrew SFU1610-1000mm
Nema34 stepping motor (34HS15660) 12.0 N.m 6.0A
Stepper motor drives the DM860H
The Z-axis sits on a ready-made aluminum plate like the Y-axis at 50CM Same rails and motors as Y axis
As for the spindle, I really have no idea which one I need, some of what I asked suggested I take it.2.2kw water cooled spindle kit CNC
This spindle
Also about machine control I don't have much idea
I played a bit with Mach 3 so I thought about this cardMach 3 CNC Control Card 3axis XHC MK4 CNC
This card
Am I missing something? Is something wrong?
The X axis is already ready, what I need to prepare right now is the Y axis and Z axis where you can change what you want,
as well as the spindle I have not yet purchased and also the card. I would be very happy for any help on this
