Originally Posted by
disneytoy2
Greetings!
Everyone has always been very helpful here.
Its been awhile. I need to build this 24x24" y axis. Think large size 3D printer for printing clay. See photo. My base is 3/4" Melamine, I have 2 20mm linear slides with 4 Bearing blocks, I will run a Small Nema 23 with 22 tooth Pulleys. I have on order HTD3M 15mm wide belt.
[You're just building the Y axis? What about X and Z? Is your plan to avoid using screws or R&P by using long belts to move the stage? ]
My rails don't have mounting holes.
[How are you planning to fasten them down?]
The Bearing slides have 4 6mm mounting holes. I need to have springs, so I can Tram the bed.
[Where would the springs go, and how would they help with tramming?]
So, I was going to run a homemade bearing idler on one side and the Nema 23 with 22 tooth pulley on the other.
[That's for tensioning the belt? Have you figured out a mechanism to move it back and forth?]
I would appreciate any thought?
I have some separate parts I'm working on I will discuss in other posts.
Thanks!!!
Max
