585,719 active members*
4,422 visitors online*
    Ghost in my machine
    I have a DIY cnc router that I have had for years. I recently did a few up grades like converting from lead screws to timing belts, adding a rotary axis, modifying the router mount and the like. The machine has been working perfectly up until today. While cutting parts for a new dust shoe to fit the new router mount things started going sideways. The machine would follow the correct toolpath for a while then suddenly go off course. It would make a straight line instead of an arc and pause for a short time before carrying on. A few days ago I cut the parts for a marble machine out of 1/4" plywood and everything was good. I suspect a driver issue but not sure. Any suggestions? BTW I'm running Mach 3.
    Re: Ghost in my machine
    Sounds like it might be a mechanical issue?
  1. Jcut Router, ghost in the machine
    By danielcoyle in forum Chinese Machines
    Last Post: 12-06-2018, 05:17 PM
  2. The Ghost in the Machine
    By PaulRowntree in forum DIY CNC Router Table Machines
    Last Post: 12-13-2012, 06:20 PM
  3. Okuma LB15 Ghost in the Machine
    By ghyman in forum Okuma
    Last Post: 11-14-2011, 07:27 PM
  4. Ghost in Machine... K2 3925 problems.
    By mtnbikr100 in forum K2CNC
    Last Post: 12-11-2010, 06:56 PM
  5. ghost is here
    By nerginer in forum Waterjet General Topics
    Last Post: 02-18-2007, 06:19 PM
