585,759 active members*
3,910 visitors online*
    Sep 2014
    Bad finishing issues
    Hi all having trouble to make decent finish on my cnc converted lathe
    Getting random strings (check photo)
    So min diameter 10mm
    Max diameter 29
    Spindle rpm 1800
    Feed 0.15mm per revolution
    Insert 55 degrease 0.4 mm tip
    Any suggestions where i need to look to make better finishes
    May 2014
    15
    Quote Originally Posted by cange View Post
    Max diameter 29
    Spindle rpm 1800
    Do you have a centre in the end.
    What kind of material is it.
    Are you using the proper chip breaker for the material.
    What depth of cut are you roughing and finishing at
    Re: Bad finishing issues
    What depth of cut are you at? Your finish looks like that of a loose machine. Best way to get better results from a loose machine is to drive it harder. A heavier cut will push all the slop in the machine against the stops and will eliminate a lot of your finish problems. That finish looks like the machine dancing around within it's slop envelope under too light of a cut.
    Basic cold rolled steel is not great for fine finishing either.
    Dave
    May 2016
    526
    Check your backlash that tool is jumping possibly due to x and z axis not moving correctly or as previous poster said use at least 1mm finish cut to push the job
    Sep 2005
    272
    Yes more depth of cut
  1. HDPE milling finishing issues - please kindly help!
    By ecl66 in forum Glass, Plastic and Stone
    Last Post: 06-08-2016, 02:22 AM
  2. Replies: 1
    Last Post: 02-29-2016, 01:26 AM
  3. Surface finishing issues
    By fadalmatt in forum Mastercam
    Last Post: 02-24-2015, 01:38 AM
  4. G540 Mach3 Display Issues & Slave Axis Issues
    By umustsurf in forum Gecko Drives
    Last Post: 09-30-2011, 03:23 AM
