584,858 active members*
4,583 visitors online*
Results 1 to 8 of 8
    Oct 2018
    20
    enroute and aspire
    Help a green horn figure out the difference. Thanks. To be used for millwork on an avid cnc.
    Re: enroute and aspire
    Enroute comes in different versions, with different levels of features. Enroute Pro is much more powerful than Aspire, but costs more than 3x as much. They also have a subscription for $1100/year.
    Aspire probably has more features than the Basic version of Enroute, though.
    Oct 2018
    20
    I am trying to figure out if the Aspire would work trouble free with my cabinet solutions software but cabinet solutions recommends the enroute and Avid recommends the aspire....Of course cost is the issue here.
    What are you expecting to do?
    Does your Cabinet Solutions export .dxf files and a cutlist or parts file (CSV)?
    I believe that the Pro version of Enroute can work with that much better than Aspire.
    Aspire has a free demo version, though. Download it and see if it will do what you need.
    Oct 2018
    20
    I am just wanting to cut cabinet boxes. Cabinet Solutions says Aspire will not work, it has to be enroute. My current plan is 4x10 or 5x10 pro version, not sure if the mach 4 is the way to go yet, building a vac table for it and using the cnc depot s30. as long as the 18000 rpm over the 24000 isn't going to be a problem, then making it all actually work...I guess the s30 isn't actually plug and play. All thoughts and opinions on this are welcomed.
    1206
    I might be wrong,but which of the additional capabilities of Aspire are justified for cabinet boxes?You can probably do it with Vcarve and save a chunk of money.
    Cabinet Solutions website has basically zero info on their cnc export.
    You need to learn and understand how the process works, before you spend your money.
    Most likely, Cabinet Solutions is exporting individual .dxf files for each part, alonf with a .CSV "parts" file that contains part sizes, quantities, .dxf names, and other things.
    Enroute is probably reading the parts file, and subsequently reading the .dxf files, creatings toolpaths, nesting the toolpaths, and exporting the g-code, all in one automated process.
    Aspire can do a limited version of this.
    1) Aspire has a batch .dxf import gadget, that will import all .dxf files from a folder. This has a few limitations. One, all parts would need to be the same thickness. Two, there's no way top specify individual part quantities, so you'd need a unique .dxf file for every part.
    2) After doing the batch import, you can select all the parts, and nest them fairly easily. I suspect that Enroute would allow you to specify grain direction on a per part level, so that parts with grain direction would not be rotated during nesting, but parts without grain could be rotated. With Aspire, this would be a global setting during nesting.
    3) Once nested, you would use toolpath templates to automate toolpath creation. Once toolpaths were created, you'd need to manually export the g-code for each sheet of nested parts.
    I've never used Enroute, but I've been doing this type of work every day for over 20 years (Currently using AlphaCAM). Once you export from your cabinet software, processing for the CNC should be a " 1 button click" process, with the right software. With the wrong software, A 1-2 minute process could take an hour or two, or longer.
    You don't need more than 18,000 rpm to cut cabinet parts. Our $150,000 router has an 18,000 rpm spindle, and cuts 5x faster than an AVID machine will.
    Oct 2018
    20
    wow thank you. Cabinet solutions has a little video on how it works, but still a bit greek to me.
  1. Aspire from Vetric vs. Aspire from Alphacam
    By jooooooe in forum Aspire
    Last Post: 06-04-2015, 04:52 PM
  2. Enroute to ASpire?
    By duvaldesigns in forum Vectric
    Last Post: 05-17-2012, 06:51 PM
  3. Enroute vs Aspire
    By gary545 in forum EnRoute
    Last Post: 05-31-2011, 09:58 AM
  4. Hi New to CNC & Enroute
    By CNC Oz in forum EnRoute
    Last Post: 01-04-2010, 09:22 AM
  5. Enroute anyone?
    By trooper55 in forum Uncategorised CAM Discussion
    Last Post: 05-26-2008, 03:58 PM
