585,973 active members*
3,948 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Vacuum Tables - Need Opinions for Machining Acrylic
    Apr 2006
    7
    I've been a member for a while now, ended up getting a XZero Raptor with a 23" x 40" working area and t-slot table and I've been using that for my home based business (dedicated garage workshop) for a few years now.
    I'm looking at making things more efficient and I've been wanting to make a vacuum table or maybe buying one. I'm mostly using 1/8" diameter bits and I'm usually cutting into ACM (Aluminum Composite Material - Dibond, etc.) and acrylic. I may do thin aluminum (< 1/8" thick) in the future.
    It seems that the best solution for the ACM is to have a "bleeder" type vacuum table - I would section it off into 2 areas. 1 area with dimensions matching the thicker acrylic that I cut/engrave. The second section would cover the rest of the working area. I would likely use 2 shop vacs or Lighthouse vacuum motors, one for each section - with everything running I may need to get an electrician to run some wire but I will likely get an electrician anyways as working in the garage in the winter is a bit torturous and a 220VAC heater would make working in there less miserable especially after the garage doors are insulated. The ACM I tend to cut through but it usually holds well together via chip packing and I'm doing larger pieces (I will cut a 4' x 8' in half and feed it through the machine section by section).
    I am a bit concerned about suction power for the acrylic however as it may sometimes have a slight bow in it. As the acrylic is always 19" x 24", I've been thinking of having threaded inserts for the 4 corners as well just to help minimize side to side motion - I would drill holes in the corners then use machine screws in addition to the vacuum. Currently I've been using a thick plywood spoilboard with 25+ Kreg screws. Each time I machine the acrylic, in addition to everything else, I have to rearrange the screw holes and I pre-drill with the CNC and increase the size on the acrylic with a hand drill. Then I screw everything down. This time tends to add up. I do not need to cut through however, I leave a thin layer of material. When cutting out the pieces I use pre-mask (typically used in signage for covering/protecting decals) and flip over the material. I have to indexing pins matching indexing holes in the acrylic and I line those up. I then use about 1/3rd of the screws but I still need to screw things down. After that use an engraving bit to finish cutting everything out. The pre-mask and screws work well enough to hold things together for my needs but I imagine a proper vacuum table would save me quite a bit of time. For this I think a vacuum grid (with rubber gasket) would work better. It sounds ridiculous to me but I'm considering having a separate aluminum vacuum table for the acrylic on top of the larger 2-section vacuum table, this would only be necessary if the holding force is not enough to keep the acrylic in place. This would likely be purchased and I would have some sort of indexing system to fix the vacuum grid in the same place while being removable.
    I'm not too concerned about Z clearance as I work almost exclusively with sheet materials so it's OK that I lose some Z height with a couple vacuum tables. I would design space for aluminum T-slots to be attached to the 2-section vacuum table for clamping flexibility. Any opinions on whether I would have issues with a bleeder type vacuum table on my 19" x 24" acrylic? Again I am mainly machining with 1/8" bits. My goal is to cut setup time. Thanks in advance!
    Jun 2018
    362
    Re: Vacuum Tables - Need Opinions for Machining Acrylic
    For your acrylic works, consider combining the vacuum ideas along with a fixture jig for your blank work pieces.
    What I mean by that is use the vacuum to hold your acrylic flat but mount the blank sheets within a pocketed (or elbow type) fixture to provide the X, Y co-ordinate alignments you mention. You mentioned locating pins, this involves drilling to get the work piece aligned whereas the pocketed/elbow fixture avoids these steps. You have your X,Y zeros at (say) one corner. You can then either use that as a reference or use an offset for X and Y to use a center starting point for two-sided jobs.
    I can also highly recommend the use of a spring loaded engraving tool such as the one available from Spring Engraving Tool
    This helps overcome irregularities in work surface to tool height differences.
    I ordered one about a week ago and tried it yesterday for some acrylic engraving with exceptionally good results on the first go! Very impressed!!
    Very impressed with the quick delivery too.
    Cheers,
  1. Stock vacuum tables - how are they
    By gfacer2 in forum Chinese Machines
    Last Post: 03-17-2016, 05:04 AM
  2. vacuum tables and pumps
    By cabnet636 in forum Camaster
    Last Post: 08-24-2015, 12:29 AM
  3. Let's see your vacuum tables !
    By cyclestart in forum DIY CNC Router Table Machines
    Last Post: 05-09-2011, 12:50 PM
