585,930 active members*
5,347 visitors online*
Results 1 to 7 of 7
    Oct 2005
    1145
    Tormachs new 2x4 router (;-)
    Tormach has a sweet looking NEW 2x4 router.
    (;-) TP
    Dec 2008
    740
    Re: Tormachs new 2x4 router (;-)
    Quote Originally Posted by vmax549 View Post
    (;-) TP
    https://www.cnczone.com/forums/torma...ml#post2332932
    (;-) Step
    Jun 2006
    3063
    Kind of expensive at $14k isn't it?
    Oct 2005
    1145
    Sounds resonable to me. Cast iron table , welded steel frame, linear way , ball screws, water cooled spindle with chiller, Commercial controller, Support.
    The only thing not great about teh router is teh low Z height. It needs to be 12" instead of just 6" . That would allow you a great 4th axis option.
    (;-) TP
    Nov 2007
    2151
    (;-) TP
    What I was thinking! A look thru the owners manual does show a A axis connection. That leaves only 5" or less for 4th axis material size. Maybe they plan extensions or other mod for people that want to whittle away on 6"+ material on a 4th axis.
    Oct 2005
    1145
    Even without a 4th iff you have thck material and a long enough bit to work teh full depth you will be out of Z travel and not be able to cut teh part..
    (;-) TP
    Nov 2007
    2151
    (;-) TP
    True!
    It does spec 6" gantry clearance and to me that implies the spindle with tool lifts above gantry, so user should be able to get most of the 2.5"radius turn envelope.
  1. How tough are Tormachs, namely the 1100?
    By Djstorm100 in forum Tormach Personal CNC Mill
    Last Post: 09-06-2018, 08:39 PM
  2. Hardly any used Tormachs for sale?
    By Renk in forum Tormach Personal CNC Mill
    Last Post: 05-11-2018, 01:31 PM
  3. Anyone cut/drill glass on their Tormachs
    By CadRhino in forum Tormach Personal CNC Mill
    Last Post: 12-22-2014, 11:46 PM
  4. get tormachs $2100 4th axis for $700
    By acannell in forum Tormach Personal CNC Mill
    Last Post: 10-13-2014, 11:57 PM
  5. Any tormachs in the freeport,ny area?
    By ruawake in forum Tormach Personal CNC Mill
    Last Post: 06-14-2009, 10:56 PM
