585,992 active members*
5,529 visitors online*
Thread: Print,
    Oct 2005
    1145
    Print,
    Does anyone know where the print statement prints to ? Teh manual say it prints to STDERR but what is that ??
    (PRINT, Var1 = #1)
    (;-) TP
    Jul 2017
    70
    Re: Print,
    Use (DEBUG, Var1 = #1) and they'll show up on the Status tab. Or use the LOGOPEN, LOGAPPEND, LOG, LOGCLOSE functions and provide your own file name.
    Nov 2012
    591
    Re: Print,
    STDERR ends up being the normal log file for the pathpilot (the one that you end up sending to their techs if they troubleshoot.)
    Aug 2014
    257
    Re: Print,
    STDERR is a Linux thing & in the PP environment it is mapped to the terminal program that launches PP. When using PP full screen you don't normally see this application but this is where STDERR is outputting its messages. However, these messages are mixed in with many other messages so it makes sorting them out a pain.
    You can get to this application window using the ALT+TAB key and select the "Terminal". DO NOT close this application otherwise PP will have a fit.
    If you have not already done so it is much easier to setup PP to boot into the desktop then you can view both PP and the Terminal simultaneously.
    As "old-cnc-geek" mentions there are better methods but as I recall I didn't have any success with them so I just resort to the above.
    Jul 2017
    70
    Re: Print,
    The (LOG) stuff was fixed relatively recently (PP 2.1+). It always worked, but the resulting file used to end up in a very awkward location. It now is put in the gcode folder as you'd expect. And relative folders work also if directory exists. (LOGOPEN, myprojectA/log.txt) vs. (LOGOPEN, myprojectB/log.txt)
    Its easy to forget the comma after the command portion of the comment, but that's linuxcnc syntax.
  1. cnc to 3d print
    By majstoralc in forum 3D Printer / 3D Scanner Discussion
    Last Post: 11-22-2017, 09:23 AM
  2. 3D print out
    By gene8522 in forum Signmaking Topics
    Last Post: 12-10-2011, 01:52 AM
  3. how to 3d print?
    By lasernewb in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-28-2011, 09:37 PM
  4. cant print?
    By erase42 in forum BobCad-Cam
    Last Post: 11-30-2009, 03:05 PM
  5. Replies: 3
    Last Post: 01-05-2009, 02:36 PM
