585,973 active members*
4,060 visitors online*
Results 1 to 9 of 9
    Mar 2012
    189
    tooling for Slant Pro
    Are the inserts and holders that Tormach sells reasonably good quality, or could a slant pro make use of higher end tooling? Either way what are your favorite holder insert combo for steel or aluminum? Trying to come up with a list of 8 tools that can hopefully more or less live in the turret to handle facing, turning, profiling, OD thread and parting for job shop type work. I thinking maybe ID work would probably be set up on the gang plate?
    -Jon
    May 2008
    667
    Re: tooling for Slant Pro
    Almost all my toolings was bought on EBay as 20mm shank and machined to 3/4 to fit the turret.
    They are about 1/5 of the price of what Tormach ask for the same tool.
    Dec 2013
    5717
    I bought an Accursize 3/4'' insert holder set from Amazon. https://www.amazon.com/AccusizeTools...s%2C221&sr=8-4
    Seems to be pretty good, Works fine in my Hardinge Conquest 42. The exception being the Accursize parting tool. I broke that and replaced it with a Iscar holder https://www.iscar.com/eCatalog/Item....FSTYP=I&srch=1 Available from SGTFR19-3
    As far as inserts, Shars Tool has a good selection, and are listed by type of material. Good prices, I quit buying the high price name brand, and have been using what Shar's has at 1/3 the price, have had good luck with them. For the most part I do aluminum and 304 SS, does require different inserts.
    Jim Dawson
    Sandy, Oregon, USA
    Jim, you are using that right hand parting tool and not a left hand version on the Slant-Pro? Turret or QCTP?
    Edit: NVM, they have the wrong picture shown.
    Dec 2013
    5717
    Quote Originally Posted by number40Fan View Post
    I have a Hardinge Conquest 42 with a turret. I am using the right hand version. I think you would want the right hand version on any turret tool changer. On my manual lathe with a QCTP I use a right hand version also.
    EDITED to correct the version of tool holder.
    Jim Dawson
    Sandy, Oregon, USA
    Mar 2012
    189
    What about coolant through tooling?
    -Jon
    Dec 2013
    5717
    Quote Originally Posted by maker of things View Post
    Not exactly sure what you are asking. Shars sells boring bars with through coolant holes. Not sure I have ever seen normal turning tools with through coolant, but I'm sure that someone makes them. All of my ER drill/tap holders are through coolant, and the split and solid bushings that I make allow through coolant.
    Jim Dawson
    Sandy, Oregon, USA
    Mar 2012
    189
    I am aware of tooling that is coolant through. I'm wondering if someone with a slant pro has utilized any? Not sure if the pump that comes with the machine would be able to handle pushing coolant through the restrictions within the tool bodies.
    -Jon
    Mar 2012
    189
    like this Attachment 431566
    -Jon
  1. Slant Pro - Tooling Tips and Tricks
    By keen in forum Tormach Slant Lathe
    Last Post: 09-14-2019, 02:41 AM
  2. Replies: 3
    Last Post: 12-15-2017, 02:58 AM
  3. Slant Pro turret + QC tooling problems with Fusion 360
    By WLyon in forum Tormach Personal CNC Mill
    Last Post: 08-17-2017, 04:37 AM
  4. GUIDE ME! SLANT BED CNC LATHE TOOLING. PARTING, THREADING, SPECIALTY
    By bob1112 in forum Uncategorised MetalWorking Machines
    Last Post: 02-27-2013, 03:29 AM
  5. Slant Bed Lathe Tooling??
    By slomoe in forum CNC Tooling
    Last Post: 03-11-2011, 02:44 AM
