586,009 active members*
4,787 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Simple Workshift OSP700
Results 1 to 8 of 8
    Jul 2007
    42
    Hi All,
    I am a bit stuck, been a while since I have been using an Okuma lathe and need help.
    I have a simple part, lets call it a washer for argument's sake. I need to run my main or sub program 20 times and workshift -3mm in Z per part.
    I currently have my turning program as ring.min and a schedule program as main.sdf
    I have set up the .sdf as PSELECT RING.MIN,,,Q20
    M02
    And the ring.min as a normal program (without any header) with a VZSHZ Z-3 AND RTS at the end
    Obviously not having any luck, any pointers as to where I might be going wrong?
    Thanks -J
    May 2015
    15
    Re: Simple Workshift OSP700
    I would use Variable as counters and adding -3mm to your work offset every time, remember to put some IF commands in there so it stops when you reach 20 parts.
    Have fun Masterblaster
    Jun 2015
    4154
    hy jimmy, if you wish 2 make it work by using vzshz, you have to change from sdf & min to min & ssb, because sdf is doing some stuff after each cycle, including reseting the vzshz ( because program is re-loaded )
    if you wish to keep the sdf&min, you could use a common variable, in order to shift the origin, but this seems pointless, because sdf is using Q, and, because you can't read the Q value, you have to read the common variable, so sdf seems useless ... again, one more for the min & ssb combo
    also, using sdf leads to downtime ( but this is it when there is limited memory )
    if you wish to keep the sdf&min, and have a nice code, then replace vzshz with vzofz ( i don't know if this works for your osp )
    in the end, whatever you do, you should reset the master counter ( eq reset the common variable, by para\edit, or by using a presetter program )
    more tricks here ( at point 2 is a code that auto-resets the counter, located inside main program ) : https://www.cnczone.com/forums/okuma/369696-cnc.html
    kindly
    ps : use M02 inside *.min, and END inside *.sdf
    Jul 2007
    42
    Thanks for the help guys, looks like I need to do some more reading in the book.
    Might go with the .min & .ssb option jeez they make this difficult. So easy on a Fanuc haha!
    I'll keep you posted....
    Jun 2015
    4154
    NOEX VZOFZ = 100
    CALL OSUB Q20
    M02
    OSUB
    // content
    NOEX VZOFZ = VZOFZ - 1 ( change origin before rts )
    RTS
    ... avoid mid-program reset / kindly
    Jul 2007
    42
    OK so looks like I have had some success, went with the .min and .ssb option
    Called my sub prog OSUB.SSB and put OSUB as a header and RTS at the end
    MAIN.MIN
    N100 V1=0
    N200 CALL OSUB
    N300 V1=V1+1
    N400 G91
    N500 G50Z3.25
    N600 G90
    N700 IF[V1 LE 20]GOTO N200
    N800 M02
    Now to run 2000 of these rings haha!
    Jun 2015
    4154
    Code:
       V1 = 0
       N200 CALL OSUB V1 = V1 + 1
       G91
       G50 Z3.25
       G90
       IF [ V1 LE 20 ] N200
    M02
     ( . . or next shorter code . . . . . . . . . . . . . . . )
        CALL OSUB Q20
    M02
    OSUB
        // next line should be before rts
        VZSHZ = VZSHZ - 3.25
    RTS
    so, you open the chuck only once / 20 parts ? don't you have overhang problems, are those really thin ? just asking / kindly
    ps : you can have the osub content inside the min file, thus is not critical to have the osub inside a separate *.ssb file; if program is simple ( small or few soubroutines ) then i put them all inside the min, otherwise, for more complex parts i use several ssb's, one for each operation, in order to achieve modularity
    Jul 2007
    42
    Yep its a piece of seamless stainless steel tube, making decorative rings 1.5mm thick using a 1mm part off tool.
    It's been running perfectly, thanks again for the help
  1. Okuma Cadet OSP700 alarm 1055-20
    By b1apt in forum Okuma
    Last Post: 05-29-2022, 02:15 PM
  2. File PC for OSP700
    By CLM_Martins in forum Okuma
    Last Post: 10-15-2019, 01:20 PM
  3. How to run chip belt on Okuma LCS15 + OSP700?
    By testpilot in forum Okuma
    Last Post: 01-15-2014, 10:16 PM
  4. inch to metric Osp700 L
    By Berzunza in forum Okuma
    Last Post: 05-15-2013, 12:45 AM
