585,741 active members*
5,238 visitors online*
    Nov 2019
    Smile Mori Seiki sv 400 msc-501
    Hi, I have recently bought an Mori Seiki sv400. Every time I run on OSP the door unlock switch turn on. Does anyone have an idea of how to fix that? Thanks
    Re: Mori Seiki sv 400 msc-501
    1997 Mori SV50 MSC-518 - Data Tables -
    D461.2 - M1ULK
    1 = When given an M01 command door is unlocked.
    0 = When given an M01 command door is not unlocked.
    You will need to look in the back or the electrical manual for your Data Tables setting instructions. I don't think you can see the code M1ULK on the screen of the control. The chance that D461.2 is the same on your machine is not good.
    M1ULK is what you are looking for.
  1. Mori Seiki DL 151
    By zavateandu in forum Mori Seiki lathes
    Last Post: 09-03-2019, 06:13 AM
  2. Mori seiki SL1?
    By Redzilla in forum Mori Seiki lathes
    Last Post: 05-17-2016, 11:02 PM
  3. Mori Seiki SV-503 - MSG-501
    By smecher in forum Mori Seiki Mills
    Last Post: 02-19-2014, 04:45 PM
  4. Did Mori Seiki Buy Hitachi Seiki?
    By Billet Sean in forum Mori Seiki lathes
    Last Post: 05-05-2011, 04:12 AM
  5. Mori Seiki Sv-503
    By mr-seiki in forum Servo Motors / Drives
    Last Post: 06-04-2010, 02:52 AM
