585,977 active members*
4,080 visitors online*
    Jun 2017
    143
    TNGv2 Spindle button problem
    If you are using scripts to manage M3, M4 and M5 and aren't using any of the on board outputs (my spindle is controlled using an I2C board), so under Settings-Spindle all the output pins are set to ---. When you click the spindle toolbar button or run M3/M4 the spindle state doesn't change (ie. not highlighted). When you click the button again rather that running the M5 script it runs the M3 script again.
    Cheers
    Simon
    Mar 2017
    1311
    Re: TNGv2 Spindle button problem
    Spindle (and Mist, Flood) state is tied to output pin. I'll check what I can do.
    Mar 2017
    1311
    I'm working on this issue right now. Next release should have this resolved.
    Jun 2017
    143
    Thank you. I will test it for you when released. Thanks for all the great work.
  1. TNGv2 Spindle Speed Recognition is unstable
    By Gnewko in forum PlanetCNC
    Last Post: 11-05-2019, 10:31 PM
  2. Replies: 2
    Last Post: 10-18-2019, 12:12 PM
  3. WATERJET CYCLE START BUTTON PROBLEM
    By isheeeljan in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-23-2015, 06:31 AM
  4. spindle button F5 clockwise, but not for pwm spindle
    By protrackcorp in forum Mach Wizards, Macros, & Addons
    Last Post: 01-23-2013, 04:27 PM
