585,715 active members*
3,785 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Fuling DZB300 series VFD and Spindle
Results 1 to 7 of 7
    Oct 2019
    20
    Question Fuling DZB300 series VFD and Spindle
    Does anyone know what the VFD parameter settings should be for a Furing DZB300 series VFD connected to a GDZ-23 spindle?
    15362
    Re: Fuling DZB300 series VFD and Spindle
    Quote Originally Posted by BJM737 View Post
    You have to have all the spindle Spec's to do the Parameters, I most likely have a Parameter list
    Spindle
    Max RPM=
    KW=
    Voltage=
    Amps=
    Mactec54
    Oct 2019
    20
    I have all of the settings for the spindle, KW 2.2, Max RPM=24000, Voltage 220vac, amps 8.... Now how do I connect the BOB to the VFD. Is my spindle controlled by step and direction or by PWM? Do I connect to the VI-ACM? how exactly do the BOB and the VFD connect?Attached is the BOB I have
    15362
    For the On/Off you will use one of your Relays and is connected to S1and DCM
    The analog output 0-10v from your Breakout Board is connected to VI and ACM , see that this is working 5v=12000 MDI M3 S12000 =5v at the output if this is working correct then you can connect it
    Parameters also need to be set for using remote control
    Mactec54
    Oct 2019
    20
    Thanks mactec54.... I now have the wires connected correctly and the spindle rotates on command at speeds given by the "S" command. I turn the reostat on the breakout board to tweek the voltage but nothing happens wish I had a manual for this board.
    15362
    The pot on the board may not be for the 0-10 control
    So have you checked with a meter the output at say 12000 RPM at the board M3S12000 it should be around 5v
    Mactec54
    Oct 2019
    20
    Yes the RPM is very close, we input M03S12000 and we get a voltage very close to 5 VDC maybe 5.1 or so, and checking the spindle speed with a digital tach it is revolving at around 12000 RPM.
  1. Fuling inverter DZB300 or DZB200
    By bivegele in forum Phase Converters
    Last Post: 10-21-2021, 03:19 PM
  2. Fuling 200/300 B Manual
    By rbraeking in forum Mach Wizards, Macros, & Addons
    Last Post: 06-16-2018, 01:53 PM
  3. Need help: Help me identify this VFD FULING
    By rajshinai in forum Spindles / VFD
    Last Post: 08-27-2014, 08:29 AM
  4. Fuling Inverter spindle speeds and feed rates
    By alanstclair in forum Chinese Machines
    Last Post: 07-17-2012, 11:21 PM
  5. Fuling DZB200M and Spindle Motor Wiring
    By mutski in forum Phase Converters
    Last Post: 02-26-2011, 06:17 AM
