585,987 active members*
4,316 visitors online*
    Nov 2019
    Fagor 8025 GP following errors
    During replacing the CRT monitor with LCD upgrade we lost our parameters, The machine was running great other than we could not view the screen. After some assistance we reloaded the parameters that the machine mfg gave us, however now if we run the controller above 4% we get follow errors for the X & Y axis theses are the only 2 axis we use. Is there a parameter that is causing these errors if they exceed a certain value? Again nothing was changed with the drives we just lost the parameters. the machine mfg stated it could be from worn motors, drives, bearings ETC, but it ran perfect before the lose of the parameters.
    Jul 2011
    12
    Re: Fagor 8025 GP following errors
    Normally you adjust following error on the drive itself, but if it ran fine before I can't see that being an issue. Are you encoder parameters set properly?
  1. Fagor 8025 help!
    By rostat in forum Fagor Automation
    Last Post: 04-29-2015, 02:59 AM
  2. Fagor 8025-TG
    By bpatel in forum Fagor Automation
    Last Post: 02-10-2013, 08:39 AM
  3. fagor 8025 G
    By fernandovergara in forum Fagor Automation
    Last Post: 07-07-2012, 03:38 PM
  4. Fagor 8025
    By rosli in forum Post Processors for MC
    Last Post: 11-17-2011, 10:40 PM
