585,991 active members*
6,176 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > Mazak QT8N with T plus control- Power Help (please)
Results 1 to 6 of 6
    Jun 2013
    25
    Helping someone get a 1994 Mazak up and going again. It was supposedly running a few weeks ago, but you know how that goes. 3 phase power into the machine is good. Green start LED on front of control is lit. Red button is not. In the back cabinet, one of the small power supplies has a red LED on it and measure 24v. The other power supply is not lit up. I believe it receives its power from the main power supply board. This board is located with the other boards in a rack style setup. This board has nothing lit on it. I measured 50 volts going into the board. On the board, it says 100v IN.
    Does anybody have any information such as a power flow control chart? What about an electrical diagram for T-plus control. Where does the power supply board receive its power form?
    Thanks for the help!
    Jun 2013
    25
    Re: Mazak QT8N with T plus control- Power Help (please)
    Small update. We were told is was running on 220volts. Pulled the cover off to verify lugs on transformer and I am not really sure what it was set on, but it was not 220v....We have action now. On to the next problem.
    Breaker QF12 trips immediately. Anybody point me in the right direction as to what that belongs to?
    Jun 2013
    25
    QF12 breaker still pops
    Light on power supply has a red led lit up for AC fail... from what I have read, it can be caused by a few things. Low/High AC voltage....It reads 107 which is within range. Second option is short to ground on 24v power supplies. Voltages on power supplies look fine. Removed output wires from power supply, no change.
    Also, the KM21 main power supply contactor isn't pulled. At what point should that energize?
    Sep 2007
    66
    Hi
    Did you solve this problem??
    greetings bertus
    Feb 2017
    No i did not, any suggestions?
    Sent from my SM-N960U using Tapatalk
    Sep 2007
    66
    hi
    no i have same sort of problems
    maybe this link will help,
    MITSUBISHI MAZATROL T PLUS Maintenance Manual pdf - CNC Manual
    greetings bertus
  1. Mazak QT8N barfeeder wiring Mazatrol T32-2
    By Taivo in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-07-2018, 07:02 PM
  2. Mazak L Plus laser error 017 Power control limit!!!
    By contrabas in forum Laser Hardware
    Last Post: 08-24-2016, 09:39 AM
  3. Mazak L Plus laser error 017 Power control limit!!!
    By contrabas in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-24-2016, 09:36 AM
  4. Mazak QT8N T32-2 Tool change position
    By PANagel in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-01-2014, 03:25 PM
  5. MAZAK QT8N stopped with Alarm 039
    By ua6lfj in forum DNC Problems and Solutions
    Last Post: 10-09-2012, 01:49 AM
