585,991 active members*
4,725 visitors online*
IndustryArena Forum > WoodWorking Machines > Uncategorised WoodWorking Machines > Shopbot PRT Alpha, upgrade to Acorn / Gecko g251x, power supply question.
    Feb 2014
    Hello all,
    I was hopping someone could help me. I have a shopbot PRT Alpha and I am upgrading to a Acorn_REV4 CNC control boards with 4 gecko g251x drivers using the original Vexta PK299-01AA stepper motors. I would like to use meanwell din power supplies and I was thinking that a separate power supply for each motor would be better, is this true? I did notice that the g251x drives have a minimum req of 15vdc, am I reading that right? If true then I could NOT use "MEANWELL MDR-40-12" these would be to small for the g251x?
    If I just went with one din power supply which one would be best?
    Thank you for your help in advance.
    Regards,
    Devin
    Re: Shopbot PRT Alpha, upgrade to Acorn / Gecko g251x, power supply question.
    Powering the steppers with less than 48V will result in poor performance.
    Jan 2010
    77
    The pk299 was not a shopbot alpha. Anyway, asking on the centroid forum would be best. Leadshine drives will be much smoother than gecko. Torrid power supplies perform better than switching meanwell's and Ger21 is spot on about keeping the voltage up.
    Feb 2014
    Thanks for the help, I called Gecko and asked. I ended up going with a "MEAN WELL SE-600-48 AC to DC Power Supply, Single Output, 48V, 12.5 Amp, 600W, 1.5"".
    Thanks again!
  1. Gecko G202 Power Supply Voltage Calculation Question
    By Biggermens in forum Gecko Drives
    Last Post: 07-24-2018, 05:43 PM
  2. Replies: 0
    Last Post: 07-01-2015, 06:12 PM
  3. alpha power supply error code
    By samu in forum Fanuc
    Last Post: 04-24-2012, 05:01 PM
  4. FANUC Alpha Series power supply input power limits
    By tcom-frazzled in forum Uncategorised MetalWorking Machines
    Last Post: 01-17-2012, 06:07 PM
