584,837 active members*
5,284 visitors online*
IndustryArena Forum > MetalWorking Machines > Kitamura > Mycenter 2Xi High-Gear Spindle Orientation
    Nov 2019
    I have a Mycenter 2Xi with a Fanuc 16i control. Occasionally the spindle orientation during tool change will be as much as 5-10 deg off. Meaning that the drive dogs will not be in the correct position for the ATC arm to put the tool into the spindle. This will only happen when the spindle is in High Gear, the spindle must be switched into low gear for it to reliably orientate to the correct position. I have searched the manual and can not find any help on this.
    Nov 2012
    59
    Re: Mycenter 2Xi High-Gear Spindle Orientation
    Ive had the same issue on my 3xi. one of my morning routines is to make sure I do a good spindle warmup going through the high and low range gears 500rpm-15000. Then before running any programs I will call
    G28G91Z0; cycle start
    M19; cycle start
    "M19" is the Fanuc macro for spindle orientation on these machines. Then just check to make sure the spindle is oriented correctly. If it is, Ill just call out a tool change to double check and go about my day. if its not, sometimes Ill have to reboot the control. (sucks since you have to do a spindle warmup again)
  1. Mazak M32 H500/50N spindle noise by High gear
    By Karsue in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-16-2017, 05:03 AM
  2. rubbing noise upon spindle stop from high gear
    By fastfrank in forum Haas Mills
    Last Post: 01-07-2010, 04:18 AM
  3. VF3 spindle high gear fault alarm #117 help!
    By JHR1 in forum Haas Mills
    Last Post: 01-01-2010, 05:39 PM
  4. spindle with low and high gear ratio
    By visky in forum LinuxCNC (formerly EMC2)
    Last Post: 12-26-2008, 11:13 PM
  5. Replies: 3
    Last Post: 07-25-2008, 03:07 AM
