585,973 active members*
4,015 visitors online*
    Jun 2012
    516
    Robofil 310/510, Cutting Rates?
    Anyone have experience with the Robofil 310/510 machines running brass wire? What kind of cutting rate do you get? I've been getting between 1 and 2 in^2/hour, and this is with pretty bad flushing i.e. not sealed nozzles to a flat surface. the parts are always either various shapes that dont allow it, or they have enough holes in them that the seal doesnt really happen.
    My machine has the brass generator, but I have also tried out stratified wire and get less wire breaks when running it, but only say 10% faster cutting rates over brass. These rates include messing with every parameter like B, Aj, WS, FF etc. To me it seems slow, I thought I should get like 6^in/hr and better if able to have sealed nozzles.
    Let me know your experience with the Robofils, I'm on the fence about dumping a decent chunk of money into this machine to replace the machining cables, maybe a PCB or two.
    Nov 2005
    9
    Re: Robofil 310/510, Cutting Rates?
    I have 5 Robofil and I cut parts with bad flushing conditions everyday. I can speed up to 7-8 sqr inch per hour. With good flushing 11-12.
    You can start by checking the 8 cables from the generator to the table sides and the black/brown relay on the back of the generator. When I receive a used machine they are always defect.
    I can help you to solve the problem if you want, just send me a email to [email protected]
  1. Charmilles Robofil 400 error E02 P01 ? while cutting.
    By Christeon in forum EDM Discussion General Topics
    Last Post: 10-15-2019, 02:56 AM
  2. cutting rates?
    By airbrush in forum BobCad-Cam
    Last Post: 02-18-2016, 10:29 PM
  3. MDF cutting bit that can accept low feed rates
    By ben_mtl in forum CNC Tooling
    Last Post: 08-30-2013, 02:02 PM
  4. Cutting rates for tellurium copper
    By Silentelk in forum Material Machining Solutions
    Last Post: 04-27-2008, 09:03 PM
  5. What cutting rates for a Plasma?
    By Normsthename in forum Waterjet General Topics
    Last Post: 12-03-2007, 12:06 AM
