585,560 active members*
3,425 visitors online*
Results 1 to 9 of 9
    Nov 2019
    5
    Question Not able to cut a simple circle :(
    Hello,
    I have a very annoying problem with my laser, when working with vectors, I am not able to just finish the cut/engraving of a simple circle.
    The result gives a circle where the end point does not touch the beginning point, so I get about a half millimeter not cut.
    It is very annoying, because I have to recut every single round manually after. When I engrave a raster image, I do not see this problem.
    I did tighten the belts, clean the rails, change gcode generating and sending software, change image, change GRBL version etc ...
    Here is a example to understand :
    Attachment 1 is the picture (vectorized and elements are correct) in Lightburn
    Attachment 2 is the result when I use Lightburn (0.9.0.7 with GRBL 1.1e and driver GRBL-M3) where I modified GCODE to keep the laser ON, so that I see the travels, and I see that the errors happens when the laser start a new shape
    Attachment 3 is the result on a paper with horizontal lines (software is Laseraxe CNCC 2019 v1.25c using GRBL 0.8)
    Attachment 4 is another more finer & complex cut, where you can see again the problem.
    Thanks in advance for your help, I tested all I know and I really do not know what to do.
    Jan 2008
    940
    Re: Not able to cut a simple circle :(
    What controller are you using. Have you tried lightburn to run the laser.
    Jan 2013
    630
    You lost me at simple circle. There's nothing simple about getting a multi axis machine to work well enough to cut a perfect circle.
    Nov 2019
    5
    Hello,
    @fixtureman1: yes, I did try with 2 software, including Lightburn as shown in first attachement. The Controller is a Laseraxe mini running GRBL 0.8 when using Laseraxe software, and running GRBL 1.1e when using Lightburn (Configured as GRBL-M3). I cannot upgrade to GRBL 1.1f+
    @Kenney Duval: It is not really about having a "perfect" circle, the point is that ANY vector shape is not finished, half a millimeter is missing on each one. It is a real pain.
    Jan 2013
    630
    If you try to produce a square do you end up with gaps? That may point to perhaps which axis is either setup incorrectly or is losing position/steps due to something mechanical. Is it possible that a mirror alignment is off? You mention you see it happen when the laser fires perhaps there is a voltage drop happening upon firing the laser.
    Nov 2019
    5
    Hello,
    Thanks for your reply, sorry I was doing tests on it and I was a bit sick too.
    When I cut squares, there are no gaps, they are correct.
    I do not know what a mirror alignment is, would it be that Y motor 1 and Y motor 2 are not working equally ? Mechanically, everyting is levelled and all is squared, I verifiied many times. X motor is alone, so I do not understand why it happens on X but almost not on Y. I have nema 17 (42x42x34mm, 26Ncm) motors, may I change them for stronger ones like 42x42x47, 59Ncm ?
    The voltage drop is a good idea, especially because I took the most powerful laser head for their product, which is 15w. I should maybe change the power adaptor from 12V - 4A to 12v - 6A (for example, I do not know current values, I will check this evening) ?
    Regards
    Jan 2013
    630
    Mirror alignment -
    Nov 2019
    5
    Oh ok ... my bad, I do not have the chance to have a CO2 laser, it is a simple 15w diode laser like seen in this attachment, so there is no mirror, just a focus pillar to get the tiniest light dot possible.
    Nov 2019
    5
    Hello,
    I thought your idea about the voltage drop when laser at the moment the laser is lit was very good, so I did remove the laser head and replace it with a pencil.
    Here is the result, in attachment.
    Basically it gives the same problem at the same places ... AND it highlights an interesting thing : at the end, the laser goes back to origin, and we see that it is NOT at the same place. I think it confirms missing steps, but I do not know for which cause.
    I did order 1 stronger motor and a new GRBL controller board, to test each.
    Thanks for your help
  1. A circle, a simple circle. How hard can it be?
    By camasaki in forum Hobby Discussion
    Last Post: 07-18-2019, 09:21 AM
  2. Can't Machine a Simple Circle with a Probotix Fireball
    By JPX2000 in forum Commercial CNC Wood Routers
    Last Post: 12-24-2018, 02:37 AM
  3. Replies: 0
    Last Post: 09-14-2015, 05:18 PM
  4. Draw line tangent from small circle to large circle
    By WEDDLETON in forum ViaCad / Shark
    Last Post: 07-30-2014, 05:53 AM
  5. Replies: 16
    Last Post: 02-05-2014, 08:21 PM
