Hey G'day people, I can't get it to work what might I be doing wrong...
I'm a little over always having to increase the Jog Speed in UCCNC - Its not a huge issue but the less clicks the better is the way I like it.
I found another topic on this issue in our forum but it will not work for me at all, I reboot and default Jog is still 10% which is rather irritating now..
Am I doing something wrong or is there another way of doing this.. using the current version of UCCNC which works with the Ethernet board.
I use a AXBB-E not that that should make any difference to the UCCNC settings..
Information Ive found so far bellow which is not working for me, does anyone know if UCCNC hides perhaps the ssf file in a user folder somewhere?
Cheers,
Steve
dezsoe wrote:
If you want to save your jog feed rate, use this in M99999.txt:
Code: Select all
exec.Writekey("JogSettings", "JogFeedRate", AS3jog.Getfield(913));
and in M99998.txt:
Code: Select all
AS3jog.Setfieldtext(exec.Readkey("JogSettings", "JogFeedRate", "50"), 913);
AS3jog.Validatefield(913);
and also this
by Greolt » Sat Sep 23, 2017 1:23 am
A_Camera wrote:
Just solved it by changing this line in the Defaultscreenset.ssf:
AS3jog.Setfieldtext("50", 913);
Similar Threads:
Need Help!- Default Spindle Speed
Australia Doing my head in with Z speed uccnc mach. Speed Feed
Default Max Spindle Speed
Default rapid speed?
Default feed override and manual jog speed settings?
