585,753 active members*
3,745 visitors online*
Results 1 to 8 of 8
    Jul 2019
    20
    not one Zero touch plate macros are working
    Please help. I have had zero luck with any touch off plate macros. I have searched and found several macros to try as well as asking the manufacture of my machine for a macro and none seem to work. I have read many of the threads but nothing seems to help. Maybe I am just missing something so easy it just takes another set of eyes. Either the z travels down and touches the plate and then does nothing (That one was the best because I would just type in the .76 height in the DRO and all was good) or it will touch then run all the way up to trigger the home switch, I also have had them touch and then raise slightly and change the DRO to zero (obviously that doesn't work).
    I have people tell me there is a difference with the Chinese manufactured CNCs but no one has been able to tell me what I should do. Currently I have a Senyo CNC with a Mach3 controller. Attached is a picture of my control unit as well as the double touch, touch off plate macro. The version of Mach3 is 3.043.062
    I tried to set up Big Tex's blue screen v3.2 but that wouldn't work either. I can't find v3.4 to see if that fixes anything, however doubtful that may be.
    I am trying to cut solid wood doors but without z zero function working properly, I can't get a bottom without any lines due to the discrepancy of setting zero
    Any help, direction, where to purchase a working copy etc. would be greatly appreciated.
    Re: not one Zero touch plate macros are working
    Not sure if this will help, but this is what I use on my CNC Router. This only works correctly for me if I have the Gcode that I want to run already loaded and after referencing the machine.
    'VB Code Start
    CurrentFeed = GetOemDRO(818)
    DoSpinStop()
    ZMove = 20.00 'Total lenght of Probe to move before Stop or no Contact Made.
    ZOffset = .190 ' Plate Hight
    ZSal = ZOffset + .5 '+ Free Hight, Will possition the Proble 2 MM over the Material.
    StopZmove = 0
    If GetOemLed (825)=0 Then
    DoOEMButton (1010)
    Code "G4 P2.5"
    Code "G31 Z-"& ZMove & "F25"
    While IsMoving()
    Sleep(200)
    Wend
    Probepos = GetVar(2002)
    If Probepos = - ZMove Then
    responce = MsgBox ("**ERROR** " , 4 , "Probe **ERROR**" )
    Code "G0 Z10"
    StopZmove = 1
    Code "F" &CurrentFeed
    End If
    If StopZmove = 0 Then
    Code "G0 Z" & Probepos
    While IsMoving ()
    Sleep (200)
    Wend
    Call SetDro (2, ZOffset)
    Code "G4 P1"
    Code "G0 Z" & ZSal
    Code "(Z zeroed)"
    End If
    Else
    Code "(Check Ground Probe)"
    End If
    Exit Sub
    'VB Code Stop
    Jul 2019
    20
    I will give it a try. Thanks for the reply
    When I used that one with the gcode loaded it goes down touches the contact then goes up twice a little bit and sets the z DRO to about .42 less than it should be
    it sets the Z DRO at 1.2598 but it is about 1.7 above the board
    Nov 2012
    1267
    Here is my touch plate script. The speeds and distances are in millimeters, so change them accordingly if you are using inches.
    Code:
    SpeedCoarse=100
    MoveCoarse=-10
    SpeedRetract=300
    RetractCoarse=0.2
    SpeedFine=10
    MoveFine=-0.3
    RetractFine=5
    TouchPlateHeight=0.8
    If IsSuchSignal (22) Then
    	Ztemp=GetOEMDRO(180)+MoveCoarse
    	code "G31 Z" & Ztemp & " F" & SpeedCoarse
    	While IsMoving()
    	Wend
    	Ztemp=GetOEMDRO(180)+RetractCoarse
    	code "G00 Z" & Ztemp & " F" & SpeedRetract
    	Ztemp=GetOEMDRO(180)+MoveFine
    	code "G31 Z" & Ztemp & " F" & SpeedFine
    	While IsMoving()
    	Wend
    	call SetDRO(2,TouchPlateHeight)
    	Ztemp=RetractFine
    End If
    Jan 2013
    630
    Mach Standard Mill is so worth the handful of dollars to drop onto of Mach 3. The probing routines are awesome. Add a touch plate or tool setter and run the probe as your master tool and things get really easy really quickly.
    Most probing macros, especially those that use the GetVAR() function, will not work with most Chinese controllers.
    MSM only works with the parallel port and ESS, I believe. It won't work with Chinese controllers.
    Jul 2019
    20
    thanks for all that have replied. I have managed to get a very simple one to work. it calls for the thickness of the gage plate from the offsets tab instead of from a line in the macro
    Jul 2019
    20
    sorry i posted the file twice and do not know how to delete one of them
  1. G540 z touch plate stopped working
    By bgasser in forum Gecko Drives
    Last Post: 09-08-2019, 08:09 PM
  2. K2 CNC touch plate
    By lumenire in forum K2CNC
    Last Post: 10-06-2017, 03:47 PM
  3. Good centre hole finding macros for touch probe sources?
    By lew90nicis in forum LinuxCNC (formerly EMC2)
    Last Post: 08-29-2015, 10:24 AM
  4. z touch off plate
    By Alwaysintheknow in forum Chinese Machines
    Last Post: 06-10-2013, 03:20 AM
  5. Replies: 12
    Last Post: 06-05-2013, 06:05 PM
