512,825 active members
2,738 visitors online
Results 1 to 7 of 7
    Registered
    Jan 2007
    260
    5/32 4mm ferrule fittings
    I re-located my line from the auto-pump and the old ferrule is already crushed enough that I can't re-use it. Now I'm down with no lubrication system and can't find a source for the stupid ferrule... Do I have to go to Tormach and have to pay $20 to have a compression ferrule shipped from the USA into Canada?
    Where are you finding these size fittings? I spent half the day looking / calling around and 1/8 or 3/16 lots of places lists (no body actually HAS but they could order in a box) but I haven't found anyone who has / can get 5/32 or 4mm fittings that Tormach used for the lubrication line....
    Anyway, just a rant of frustration
    M
    Registered
    Dec 2006
    Re: 5/32 4mm ferrule fittings
    If you have a lathe they are not that hard to make from 360 brass. Not super fussy to make and have them work. Have done it numerous times.
    Junior Member
    Apr 2013
    1475
    Not sure where you are in Canada (I'm 60 miles east of Toronto) but they promise Saturday delivery to here.
    See https://www.amazon.ca/Joywayus-Compr...dp/B07P7GJCGF/
    Registered
    Jan 2007
    260
    Might order those for spares. Made up one from some brass rod tonight, probably over an hour invested in a $.50 item arggg
    (BTW, I'm 1/2 hour or so N of Toronto)
    Thanks for the link
    Registered
    Oct 2008
    1953
    When I rerouted my oil line I used a push lock fitting. Available from all of the major industrial suppliers like MSC & McMaster as well as mass sellers like , Amazon, Ebay etc. Just a couple dollars. I have more machines than just my Tormach, and I am in the process (long term) of building a couple, so I stocked up on 4mm, 6mm, 8mm, exhaust mufflers, etc. I'm sure there has to be somebody in Canada that has them.
    Bob La Londe
    http://www.YumaBassMan.com
    Registered
    Oct 2008
    1953
    Quote Originally Posted by Mooser View Post
    Thanks for the link
    More than once I've spent a couple hundred dollars of my time to make a part so I could have it today rather than wait until Monday to pick one up at the store. Its both a blessing and a curse to be able to make stuff. LOL.
    Bob La Londe
    Member
    Aug 2009
    283
    Bijur makes them.....might be helpful on your search.
    https://www.ebay.com/itm/5-32-ID-Sof...r=502064226150
  1. New 770 almost setup - oil tube ferrule missing!
    By phoglite in forum Tormach Personal CNC Mill
    Last Post: 01-20-2018, 08:26 AM
  2. Grease fittings?
    By Spotswood in forum CNC Router Parts
    Last Post: 01-08-2018, 01:36 AM
  3. I need a tool to make Copper Tri Clamp Ferrule .... is there such a thing ?
    By Goldhunter_2 in forum Want To Buy...Need help!
    Last Post: 06-17-2015, 06:23 AM
  4. Pneumatic Hose ferrule
    By fuper in forum General MetalWork Discussion
    Last Post: 12-31-2010, 11:00 PM
  5. Lube fittings
    By dblais in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-01-2008, 07:04 AM
