585,906 active members*
3,951 visitors online*
    Mach3 One stepper motor won't move
    I am replacing my computer on my plasma table. I loaded Mach3 on the new computer set it up with the same setting as the old one. Everything works as it should except one of my motors on the Y axis won't move. I plug in the old computer works fine. HELP!
    Re: Mach3 One stepper motor won't move
    USB or parallel port?
    Quote Originally Posted by number40Fan View Post
    Parallel port
    Double, triple, quadruple check the pin layout in Mach 3. If that doesn't work, can you swap the ports between the two computers?
    Jan 2007
    626
    You have 2 Y axis Steppers?
    Have you set one to slave to the other?
  1. GRBL 1.1 Stepper motor won't move
    By Twiens99 in forum Arduino
    Last Post: 11-25-2020, 01:01 AM
  2. my stepper motor NEMA 23 do not move but make a little noise
    By envergure in forum Stepper Motors / Drives
    Last Post: 05-16-2016, 05:40 AM
  3. Replies: 9
    Last Post: 12-29-2014, 05:36 AM
  4. Stepper motor move barely!need help
    By mike3385 in forum Mach Lathe
    Last Post: 09-27-2010, 03:48 PM
  5. How to you make a stepper motor move?
    By HereinCS in forum DIY CNC Router Table Machines
    Last Post: 08-24-2010, 06:45 AM
