585,880 active members*
6,247 visitors online*
IndustryArena Forum > Mechanical Engineering > T-Slot CNC building > Use small steps to keep plates aligned?
    Jan 2007
    626
    When building a CNC Router and you needed to mount a vertical gantry plate to a horizontal plate, that attachs to the Linear rail and ballscrew block, would you machine a small 'step' in the base plate to ensure correct placement/alignment of the the 2 parts?
    It seems to be a good idea, but i'm not sure i have seem too many people do it. Just wondering if there is an obious reason not to do it.
    No adjustment avaialble?
    Steve
    Attachment 431756
    1222
    Re: Use small steps to keep plates aligned?
    Like you,it isn't something I have seen and I don't think I would take the time to do it.On the other hand I would add a web on the outside of the sectional view you posted, in order to keep the vertical plate from flexing.
    Jan 2007
    626
    Thanks Routalot,
    I wouldn't think it would take much to machine a small step in ones Gantry plates and the step would 'lock' the plates in position.....Maybe its too fiddly.
    I was thinking the same re:web.. Would not want to rely on that fixing to be and stay 90°.
  1. Replies: 2
    Last Post: 01-06-2017, 03:06 AM
  2. (2) Modify or Machine Small Aluminum plates
    By diyengineer in forum Employment Opportunity
    Last Post: 05-01-2010, 08:06 AM
  3. UK: Need a quote for small-ish steel plates
    By Philipf in forum Employment Opportunity
    Last Post: 04-05-2010, 08:02 PM
  4. Fixture for Small Plates 200qty order
    By stang5197 in forum Work Fixtures / Hold-Down Solutions
    Last Post: 01-14-2010, 07:10 PM
  5. Need an engraver for small 2" brass plates
    By TheMunk in forum Want To Buy...Need help!
    Last Post: 03-27-2009, 09:50 PM
