585,956 active members*
4,599 visitors online*
IndustryArena Forum > Other Machines > Other Machine Topics > Compressor opinion: Coaire
    Apr 2015
    19
    Does anyone have any input on Coaire scroll compressors? I have one that currently doesn't work and I am trying to figure out if it is worth trying to get it up and running. Everything spins, and blows air when I manually engage the magnetic contactor, I know it is an electrical problem. Just not sure if it is worth doing anything with.
    Dec 2013
    5717
    Re: Compressor opinion: Coaire
    Could be a pressure switch problem, not sure what other safety controls might be on the system, low oil switch maybe? Should be simple to fix. If that's the only problem and otherwise the compressor is working OK, then I would say fix it.
    Looks like you can download service manuals here Coaire - Air Compressors - Downloads if you don't already have one.
    Jim Dawson
    Sandy, Oregon, USA
    Apr 2015
    19
    I haven't done much with it yet, but I did test sensors. Everything seems to be ok at this point. I am thinking it is the LCD control panel. The machine was wired for 480 3 phase, but I only have 230 3 phase at my shop. Every component on the compressor is dual voltage, so I did spend a bunch of time changing over to the 230v wiring. There is some wiring that I have to change over for the lower voltage inside the control box, specifically the LCD controller transformer. I just don't know how far I want to go with this compressor. If I can't get the control to give some notion of life I do not think I will go any further. I just figured I would try and see if there is any input on these compressors.
    Nov 2012
    1267
    What kind of controller does it have? Does it give you any error message or code? If the pump itself is working, the compressor is DEFINITELY worth fixing.
  1. DIY air compressor
    By joecnc2006 in forum Hobby Discussion
    Last Post: 07-05-2014, 07:11 AM
  2. PDB/ATC compressor
    By Dark Side in forum Tormach Personal CNC Mill
    Last Post: 12-24-2011, 09:53 AM
  3. Air compressor
    By Toolz_86 in forum MetalWork Discussion
    Last Post: 11-13-2011, 01:29 PM
  4. compressor
    By WATERJET71 in forum Haas Mills
    Last Post: 05-31-2011, 11:17 PM
  5. compressor help
    By advt001 in forum MetalWork Discussion
    Last Post: 04-07-2010, 04:04 PM
