585,722 active members*
4,069 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > G201X Disable input - float then ground, or +5V then ground?
    When using the G201X Disable input, which as I understand should be connected to Terminal 12 (ground) in order to DISABLE the drive, when NOT in a DISABLE state, should the Disable input be simply floating, or should it be connected to a positive (+5VDC) point? Not sure if "floating" when not diabled would be the best solution...
    thanks
    Dec 2013
    5717
    Re: G201X Disable input - float then ground, or +5V then ground?
    That input is likely to be pulled to 5V+ internally through a resistor. I think you can safely leave it floating.
    Jim Dawson
    Sandy, Oregon, USA
    thanks Jim
  1. Replies: 1
    Last Post: 11-02-2019, 09:16 PM
  2. Frame ground vs. Electrical ground.
    By polaraligned in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-24-2008, 11:21 PM
  3. To Ground or not to Ground That is the question!
    By Mr.Chips in forum DIY CNC Router Table Machines
    Last Post: 03-16-2008, 09:10 PM
  4. Motor supply ground vs Logic ground?
    By Gashmore in forum CNC Machine Related Electronics
    Last Post: 06-07-2005, 11:21 PM
  5. To Ground or Not to Ground
    By Mr.Chips in forum Xylotex
    Last Post: 05-02-2004, 05:05 AM
