585,906 active members*
4,083 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Kollmorgen S200 Servo Amplifiers
    Needing a bit of help with some Kollmorgen S200 Servo Amplifiers.
    I have 4 which are connected to AKM31E-ACDNC-00 and 2 connected to AKM42J-CCDNC-00. These are connected to a PMDI MC4000 motion card.
    This setup has been running fine for the last 12 years on this particular machine and lots of other machines.
    Now here is the problem...........
    When i power the machine up and reset the e-stop all amplifiers are enabled fine. After a while 1 amplifier, not always the same one will fault giving 9 flashes which is Motor l-l or l-n Short, Line-to-Line, Line-to-Neutral or Line-to-PE short on the motor output causing an instantaneous over current. Then another will fault and then another.
    I have pretty much replaced everything but still getting the fault. Before i go out and buy 6 new amplifiers, has anyone got any ideas as to what could be causing this issue.
    Thanks in advance.
    Jun 2020
    Re: Kollmorgen S200 Servo Amplifiers
    Pretty Sure I'm running into a similar issue.. Any chance you found the solution??
    Nov 2022
    I am also having the same problem . Did you ever determine the issue ?
    Mar 2023
    Quote Originally Posted by pontiacguy View Post
    I am having a similar issue with my Kollmorgen S200 series drives. 9 flashed repeating... I've noticed that most of the time I can power cycle the drives and they start working again. I've also noted that this fault happens more on startup. Also have one drive that works better now that I installed a PC fan onto it.
    I've checked the cables, motors, & control boards and have found no faults.
    I'm running them in a Calypso water jet, Mark II D
  1. Kollmorgen S200 SynQnet MEI eXMP SynQnet Controller Software needed.
    By RomoliczP in forum Servo Motors / Drives
    Last Post: 10-19-2017, 02:03 PM
  2. Did I fry my servo amplifiers?
    By jderou in forum CNC Machine Related Electronics
    Last Post: 10-27-2014, 03:07 AM
  3. Fanuc Servo motors and servo amplifiers.
    By molma in forum For Sale Only
    Last Post: 09-07-2014, 11:05 PM
  4. question on kollmorgen servos and amplifiers
    By marette in forum Servo Motors / Drives
    Last Post: 07-06-2013, 11:05 PM
