585,951 active members*
3,949 visitors online*
Results 1 to 11 of 11
    Sep 2014
    5
    My new DIY metal CNC machine.
    Last winter I build a new machine. It was my first design. I had a cheap China CNC before that but I was unsatisfied with its non existing capabilities to mill in aluminium. Now I have had it for some time and I have milled A LOT of of aluminium parts for my RC helicopters so I would like to share the machine with you. I am very pleased with it in every possible way. There is 2 parts I did not manufacture myself and thats the T-slot bed and the holder for the spindel motor. These parts I bought here: https://www.sorotec.de/shop/
    If you want to build one yourself or you just are curious you can see and download all the 3D files here in Autodesk Fusion 360 format: https://a360.co/35qALxA
    The last picture shows the very first part I made with this machine which is a a little bearing holder for my smallest RC helicopter (Gaui X3).
    Here is a video of the machine machining a "Gordian knot": https://www.youtube.com/watch?v=irbxQ6aRZro
    This video shows the milling of some larger spare parts for a circular saw. The tool is 8mm and this is the most aggresive millig I have done with this machine. The result was very good: https://www.youtube.com/watch?v=wQGqnrZNEBs
    Attached Thumbnails Attached Thumbnails P1050262.jpg   P1050270.jpg   P1050335.jpg   P1050392.jpg
    Jul 2018
    6335
    Re: My new DIY metal CNC machine.
    Hi Pxpep - I like your sturdy little machine especially in the kitchen. True CNC Maker style. Peter
    Mar 2014
    1131
    Is that an rc heli main bearing housing?
    Sent from my MI 5s Plus using Tapatalk
    Jan 2007
    626
    Nice?...yes.
    1224
    It certainly does the job you built it for and has to be rated as a great success.
    Sep 2014
    5
    Quote Originally Posted by Azalin View Post
    No not exactly. Its the so called "Third bearing" which is the lower most bearing for the main shaft on a RC helicopter. I have of course also made the main bearing houses (and A LOT of other parts) on the machine. Here is a picture of it.
    May 2018
    85
    Next time my wife complains about the CNC in the garage, I’ll show her the picture of your CNC in the kitchen. Great work, those parts look very clean!
    May 2005
    3920
    Very nice build.
    I do wonder how you keep the aluminum chips out of the salad though. ??????
    Sep 2014
    5
    Well they are to heavy to penetrate the refigurator casing. A bigger problem is when I mill softer materials especially carbon fiber. The whole kitchen and my living room is covered with VERY fine dust and probably my loungs too:devious:
    Apr 2004
    5737
    You're kidding, right? Or itching a lot?
    https://www.monash.edu/ohs/info-docs...ormation-sheet
    Invest in Tyvek pajamas...
    Andrew Werby
    Website
    Mar 2018
    70
    Nice little build. If your commnt wasn't a joke remember: Some wooddusts can cause cancer.
  1. Thin stainless steel laser cutting machine for metal and non-metal materials
    By aaronhernandez in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-04-2016, 03:45 AM
  2. Metal laser cutting machine is easier to achieve diversification sheet metal
    By mornlaser2014 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-16-2014, 07:46 AM
  3. world cheapest metal &non metal cutting machine LC1325M etc
    By wklaserliu in forum News Announcements
    Last Post: 07-26-2013, 09:14 AM
  4. GWEIKE LF10 metal fiber laser marking machine FOR METAL
    By samlasercnc in forum News Announcements
    Last Post: 11-30-2012, 08:56 AM
