585,930 active members*
5,134 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > How to remove things from the visualisation
Results 1 to 2 of 2
    Nov 2019
    3
    Hi, I'm quite new to Edgecam. It's mostly an intuitive software, but there are definitely a few things lacking. As there are no YouTube video helps, I thought I'd post in here and see what response I get. I want to remove the dashed green lines from my window so that I can make the screen clearer and select edges easier, but I can't work out how to do this. It doesn't seem possible to simply right click on the lines and within the sequences there are some features that you can't change the visibility of.
    Oct 2003
    127
    Re: How to remove things from the visualisation
    if you right click on any tool or cycle in your tree, you can hide the item by selecting/unselecting the visible option for cycles and display layer for the whole tool
