@ger21, any suggestions on software? Care to share your top two or three software? ( based on your previous comment a software that uses Ethernet is prefered?)
I'm using UCCNC. A lot of former Mach3 users have moved to it, and find it a much better product. New features are constantly being added.
Many like the Centroid Acorn, claiming it's a more "industrial" solution.
LinuxCNC is good, if you don't like Windows.
There are other options, some more expensive, some cheaper.
At the end of the day, it's a matter of personal preference. Does it do what you want and need it to do. Some may meet your needs, others may not.
control software if possible i would like to be able to have a choice of running Mach 3 , Linux cnc , or Uccnc
like to machine 3D so all 3 axis moving same time
have any recommendations?
Personally if I were building another machine I would use UCCNC, thru the UC300ETH-5LPT To The Gecko540. Simple and proven system with good support
Yes, not going all the way up to 10. Not a big deal cause i just scale my drive analog input accordingly. My biggest problem with this board is/was the lack of 0V5 points for the stepper signal wiring. Also the jumper position was opposite to what is indicated in their manual. For the price it's a good deal still
i been looking at Acorn CNC Controller for $299 i don't like the i deal on there cnc 12 program is Limited to 50Kb G-code file size and if you want more add $139 w/ Centroid Pro software , is there a better alternative /any recommendations?
I went with the Acorn and really happy with it! I did go basic for awhile, was good enough to get up and running to learn everything (other than operating a waterjet I have no cnc backround). Loading each opp gets old by the time you want to start making parts though haha! Getting pro after setting up and learning it helps brake the cost up.
Everyone will tell you that their personal preference is "better". Only someone that's used multiple controllers extensively can actually tell you which is truly "better".is there a better alternative /any recommendations?
And "Better" may come down to what features one may need or use. So one might be considered better because it has specific features that another controller does not.
When considering the Acorn, don't think of the Pro software as an additional cost, as it's really just part of the overall cost.
I'm using UCCNC with a UC300ETH and UB-1. Cost is similar to the Acorn and Pro software. You can get the cost much lower with their cheaper controllers and cheap breakout boards.
Mach4 with an ESS and breakout boards cost a bout the same as Acorn and Pro software.
Eding CNC with their higher end control boards costs more than Acorn and Pro software.
If to you, "Better" means cheaper, than look at LinuxCNC.
