585,997 active members*
5,115 visitors online*
IndustryArena Forum > Other Machines > Commercial Products / Manufacturers Support Forums > CNC4PC > How do I setup a relay to turn my router on my cnc off/on
Results 1 to 7 of 7
    Dec 2019
    4
    I have my router cnc setup and working well with the Gecko 540 drive. What I would like to do now is setup the machine so I can turn the router off/on through UCCNC. Can anyone recommend what relay I should use and is there wiring diagrams to show how to hook it up?
    Thank you for your assistance.
    Bill
    Re: How do I setup a relay to turn my router on my cnc off/on
    I found the below wiring diagram indispensable when setting my G540 up. I use the relays listed on the diagram, they can be found on Amazon as well as other places.
    https://www.homanndesigns.com/pdfs/EN010_V8.pdf
    Dec 2019
    4
    Thank you for this info. My power supply is a 36V. Do you think this relay will work with a 36V power supply?
    This is the relay you are looking for:
    https://www.cnc4pc.com/ssr25a-solid-state-relay.html
    Arturo Duncan
    https://cnc4pc.com
    Dec 2019
    4
    Thank you Arturo. I ordered it. Does it come with instructions on how to hook it up to my Gecko 540?
    Apr 2016
    841
    Quote Originally Posted by BillR94 View Post
    I used this sort of relay when building an electric brewing control system a few years ago. Although they work great, they can generate a lot of heat when current is running through them. You need to add a heat sink, or risk burning up the relay. I was running 240VAC at about 23A. Since you appear to be running 120V at far fewer amps, maybe heat won't be an issue.
    On one end of the relay, there are poles for 3-32VDC for the control side. I'm not sure how it will work with 36V - you are supplying 4V too much. The other end of the SSR is for the hot power lead (the power lead with the SSR wired in series). Don't worry, the SSR is labeled. To explain it another way, you take your mains hot wire and run it to one of the SSR's power terminals. Then, you hook another hot side power lead to the other SSR terminal and run that wire to your router. The neutral wire does not hook up to the SSR.
    I hope this makes sense. If you would like to spend a few hours reading, here's a link to the instructions for the Electric brewery I built:
    Parts List for Building Your Brewery It will provide a good deal more detail, but what you want will be spread out through the instructions.
    Gary
    Dec 2019
    4
    Thank you Gary. I will try your instructions.
  1. Turn on X3 spindle from breakout board relay
    By Leon82 in forum X3/SX3/G0619/G0463
    Last Post: 01-05-2019, 02:02 AM
  2. How to get my 5v relay to turn on and on
    By SKLCNC55 in forum Mach Software (ArtSoft software)
    Last Post: 12-24-2014, 10:13 PM
  3. Newbie-> Using G Code to turn a relay on
    By Delanoman in forum G-Code Programing
    Last Post: 08-30-2009, 05:33 AM
  4. relay to turn plasma on needed with bob campbell
    By Wolfesmetalfab in forum CNC Machine Related Electronics
    Last Post: 01-04-2009, 09:26 PM
  5. Relay setup?
    By bigz1 in forum Mach Mill
    Last Post: 05-09-2007, 12:06 AM
