585,885 active members*
6,272 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > For Sale Only > Bridgeport Series ll Special Edition CNC Knee Mill
    Mar 2008
    1762
    Due to changing product lines I need to replace my existing "daily driver". Its a CNC Bridgeport Series ll Knee mill. Pictures of my conversion are documented here: https://sawmillcreek.org/showthread.php?240313
    Machine has had semi steady but light use (plastics and aluminum) and is in great shape.
    Specs: BP Series ll Special Edition.
    NMTB30 quill with Erickson Quick Change (premeasured tools)
    X travel: ~34"
    Y Travel: ~14"
    Z Travel: ~5"
    Knee Travel: ~14" (with air assist)
    3hp spindle with high/low range 150-400 rpm
    VFD with software rpm and fwd/rev control
    2832 ozin (.72kw) NEMA42 3phase Easy Servos
    50mm x 5mm pitch (2:1 reduced) ballscrews XY
    20mm x 5mm pitch (1.5:1 reduced) Z
    Step resolution sub 0.00001
    Rapids: max 300ipm (set 200ipm)
    Chip containment enclosure
    Software controlled flood cooling
    Software controlled mist and/or air cooling
    Home +/- limit inductance sensors
    OEM manual included (copy)
    One shot lube pump (manual) (electric available)
    Power: 230VAC 30A 1ph
    ~30 end mill, shell mill and drill tool holders, including numerous collet holders
    ~5200 lbs.
    Machine is currently running on WinCNC control (CNC-PC & monitor included) but can be swapped to Centroid control (buyers option)
    $12,000 including machine bolted to skid and fork lift available to load. Pickup or shipping at buyers expense. Delivery available
    Includes full day of operational training.
    [email protected] for more info.
    Gary Campbell CNC Technology & Training
    GCnC411 (at) gmail.com www.youtube.com/user/Islaww1/videos
    Mar 2008
    1762
    Re: Bridgeport Series ll Special Edition CNC Knee Mill
    Price lowered to $10,000 Buyer option to have Centroid control installed (N/C)
    Mar 2008
    1762
    SOLD!!!
    Thanks for all the inquiries
  1. Bridgeport Series 1 Mill - 2 hp - 9" x 42" knee mill
    By VTPROS in forum For Sale Only
    Last Post: 09-22-2015, 06:08 PM
  2. Bridgeport Series II Special with Anilam 3300MK 3axis controller
    By Havana in forum Bridgeport / Hardinge Mills
    Last Post: 12-09-2013, 10:52 PM
  3. Bridgeport Series II CNC with Z axis on the knee
    By autotechsteve in forum Bridgeport / Hardinge Mills
    Last Post: 09-18-2011, 12:23 AM
  4. Special Edition Software
    By seac02 in forum News Announcements
    Last Post: 03-11-2010, 10:31 AM
