523,731 active members*
2,165 visitors online*
Results 1 to 2 of 2
    Bending force calculation
    I recently read an article describing a new formula for calculating bending force. Amada's formula has some limitations. I wonder if the new method pointed out in the article is correct? Hope you guys can guide me.
    This is the link:
    https://www.machinemfg.com/calculati...n-air-bending/
    Member
    Jul 2018
    1508
    Re: Bending force calculation
    Hi MM - These days if you want to know the forces and various things going on in a press operation you simulate it using FEA. This will correctly predict the force, the deflection and the springback. Not sure why you would use an approximation theory these days. Plus you do a bend and measure the force via the machine no need to estimate it. Operators know what will bend and what won't and the machine has operational guidelines...Regards Peter
  1. Gripper force calculation
    By PIngels in forum Mechanical Calculations/Engineering Design
    Last Post: 12-26-2014, 06:56 PM
  2. Calculation Of Force In Order To Select Correct Spring
    By weaston in forum Mechanical Calculations/Engineering Design
    Last Post: 08-24-2011, 02:48 PM
  3. Simplified force/design calculation pdf?
    By diosces in forum Mechanical Calculations/Engineering Design
    Last Post: 02-19-2010, 04:20 PM
  4. Milling Force Calculation
    By diabolical7 in forum Mechanical Calculations/Engineering Design
    Last Post: 07-19-2009, 07:27 PM
  5. Clamping force calculation
    By Wiseco in forum Moldmaking
    Last Post: 08-04-2008, 07:20 PM
