585,962 active members*
3,640 visitors online*
IndustryArena Forum > CAD Software > Solidworks > Spin too large; check machine ID file
    Aug 2016
    32
    I've been running my 3D router with a fixed speed spindle motor and set the speed in the tool section at 3000rpm. Everything worked well.
    I'm now using a 3phase motor controlled by a VFD and this works OK using the tool stting window up to 10000rpm. My spindle can run up to 18000 revs but when i input this I get the title message, "Spin too large; check machine ID file".
    I can't find the file to change!
    I'm using LinuxCNC as a controller and with the exception of this speed issue it works great with SolidCAM.
    I can change the gcode manually to give me 18000 rpm but that defeats the object.
    Help please.
    Oct 2018
    Each Solidcam post processor has 2 files. A *.GPP File containing the code outputs and a corresponding *.VMID file that contains information about the machine and spindle speed. You will need to edit this to no lounger get that message. I hope this helps.
  1. "spin is not in range check machine id file"
    By alejocs in forum Mexican Club House
    Last Post: 03-23-2019, 08:43 PM
  2. Replies: 1
    Last Post: 05-29-2016, 02:08 PM
  3. Large File?
    By esadaddy in forum Fanuc
    Last Post: 01-16-2009, 06:46 AM
