585,875 active members*
3,961 visitors online*
    Dec 2019
    Needing help!
    My handheld, kdm20-g multicam. Shift key has stopped working. I've rebooted the controller. Also rebooted entire system, changed cable as well. Without a fix. Is this common and anyone else have the same problems? Assuming the device is toast. But to be on the safe side.
    Dec 2013
    5717
    Re: Needing help!
    Probably a failure of the keypad switch. Not uncommon with membrane keypads. Parts may be available, or not.
    Jim Dawson
    Sandy, Oregon, USA
