585,685 active members*
4,652 visitors online*
Results 1 to 2 of 2
    Dec 2005
    504
    4th axis label when homing
    I haven't had my 4th axis hooked up for a while. When I disconnected it I would get an error 504 Invalid parameter. Line 7 is M91/B. I tried changing some parameters but the error persisted. I've just ignored the error.
    Today I hook up the 4th axis and I'm still seeing the error. My label on parameter #131 is 11, which should be A. I did have the axis assigned as B at some point. In any case I can't figure out what parameter switched the label in the homing routine and I suspect I may have another issue because I can't move the axis. Any ideas?
    Attachment 432492
    Dec 2005
    504
    Re: 4th axis label when homing
    I have it working. I had to change the value in the cnc10m.hom file. I have it configured and working as the A axis now.
  1. Replies: 13
    Last Post: 06-25-2014, 02:21 PM
  2. Dual Y Axis Slave A Axis Homing Problems
    By guy2b1 in forum Calibration / Measurement
    Last Post: 03-03-2012, 11:06 PM
  3. X axis homing trips axis offline
    By dougputt in forum Bridgeport / Hardinge Mills
    Last Post: 01-20-2012, 10:16 PM
  4. EMC2 axis Z-axis homing and table
    By satovey in forum LinuxCNC (formerly EMC2)
    Last Post: 07-02-2011, 10:05 PM
  5. Y-axis not homing.
    By hotrob1 in forum Fanuc
    Last Post: 08-21-2009, 01:35 AM
